What is this noise? (Vid)
If it was the thrust bearing, and everything was moving towards the front of the engine, then I suppose that could cause some issues with everything setting right in the transmission? That's for the noise is coming from.
i found a vid on youtube that is very similar and it turned out to be an issue with his clutch.
if that were they case, why would it do it only in neutral and only when i let the clutch out normally? and why would it not make the noise when i let the clutch out slow?
i have the engine hoist at my house. if i'm gonna pull the trans.. now is the time to do it.
Maybe, but it's not a thin, metallic sound. It's something solid and heavy and seems to be coming from the transmission case.
I could be wrong.
Someone told me they had a faulty TOB and it sounded kinda like this. That would suck.
canihaveaevox
Aug 9, 2010 07:42 PM
jasnm21
Apr 28, 2009 03:37 PM
Jasil
Sep 4, 2007 06:54 PM
