evo 8 not moving after clutch installed
Old Mar 12, 2016 | 09:32 PM
Peter Colindres's Avatar
I'll just leave this here..
could the front diff be broken?
Old Mar 12, 2016 | 09:36 PM
roni4g63's Avatar
the car is barely moving so how do you expect to hear anything, power is probably only being distributed to your front wheels, you pretty much answered your own question, you already took your trans apart and its okay, the only other possibility would be the transfercase, get it out, take the few bolts off from where the passenger side axle exits, and crack it open, the diff is housed in there.
Old Mar 12, 2016 | 09:49 PM
ok thanks I just wanna be sure.. my first time messing with an evo, don't know anything about them really, but thanks I will do that tomorrow morning & let u know the results
Old Mar 12, 2016 | 09:53 PM
roni4g63's Avatar
hope you find your problem, one more thing, when you put everything back together, dont forget any of your transmission bell housing bolts, specially the one that bolts from the block side, if you forget that by any chance, you will get premature clutch wear, and it could even twist your crank in the long run, just an fyi
Old Mar 12, 2016 | 10:13 PM
thanks alot.. I won't forget them.. I'll get back with u tomorrow & let u know what's going on
Old Mar 12, 2016 | 10:16 PM
roni4g63's Avatar
goodluck bud
Old Mar 13, 2016 | 01:23 PM
goodluck bud
ok so i have everything apart.. how do i tell the front diff is bad? it dont look stock cause i heard stock ones are open where u can see in it but this one is closed so i cant tell.. another thing is when i opened the case to where the front diff is located the grease or oil thats supose to be in it was really black & gooey is that normal? or is it supose to be clean like the rest of the tc oil? cause when i took the lid off tc the oil in it was kind of clean until i got into the front diff it was really dark & gooey..
Old Mar 13, 2016 | 06:05 PM
3gturbo's Avatar
I believe you have found your problem. If the tcase doesnt go straight through you have a lsd from what I was told I have the wavetrac and mines the same. Unfortunately someone used the wrong fluid it looks like and you need a rebuild. Only use the factory oem fluid in the tcase.
Old Mar 13, 2016 | 07:47 PM
LetsGetThisDone's Avatar
Take pics of everything
Old Mar 13, 2016 | 09:27 PM
Old Mar 13, 2016 | 09:29 PM
wont let me post pics.. that same pic keeps popping up
Old Mar 14, 2016 | 06:35 AM
Try hosting them on photobucket and inserting the IMG link.
chrisff521
24
May 5, 2012 12:27 PM
Illrunya
Apr 7, 2011 01:03 AM
Vivid Racing
West Region
Feb 25, 2010 04:35 PM
riceball777
Sep 11, 2007 08:51 AM
hawaiian_evo
Aug 11, 2007 08:26 AM
