Setup thoughts !
Setup thoughts !
Hi guys !
Will be getting my cylinder head done soon & was wondering what your thoughts are & how much power I would be able to squeeze out.
kelford 272 cams
Kelford valve springs & titanium retainers
ARP l19 headstuds
FP red turbo (journal bearing EVO 9 housing)
Tial MV-S wastegate
Bosch 1000cc injectors
walbro 460lph fuel pump
SPP exhaust manifold & SPP screamer
Tuned on e85
stock bottom end
what are your thoughts ?
thanks
kelford 272 cams
ARP l19 headstuds
Tial MV-S wastegate
Tuned on e85
stock bottom end
thanks
Should be able to make over 500whp easy on E85. I'd port the inlet to the waste flapper to eliminate any chances of boost creep.
I'd make sure you have zero boost leaks.
The BB reds can make over 600whp dynojet, You would have to make the call on the JB with what you are comfortable with.
Getting the head fully serviced & with new internals & valve stem seals
also I want the head gasket done along with the timing belt, So I figured to get everything done at once so If i want to later on build my bottom end, I can do without touching the head
Looks like you are going to need more injector . 1000's are going to be out quickly on E85. I'd also recommend getting more voltage to that pump.
I'd step into some 1650's or 1700's if you plan on making over 500whp.
Although I forgot to mention the pump is getting re wired
Bosch makes a 1600, but cheaper isn't necessarily better. ID2000s would probably run nicer, might not hurt to read around what people are using for the 500-600 range.
bluegsr
Apr 1, 2010 08:04 AM
darkwolf
32
Apr 18, 2009 08:29 PM
