Evo IX 5th-Gear Grind
Old Jul 16, 2017 | 07:52 PM
  #46
FJF's Avatar
FJF
As I understand, this is the reason for 5th gear grind on some Evos: due to the large gap between 4th and 5th, the latter being very tall, the synchro wears abnormally if one tried to shift quickly. In essence, the synchro doesn't have a chance to catch up and becomes damaged over time. The solution is not to shift fast from 4th to 5th.
I only have ~50K on my IX, albeit quite a bit of it at WOT, so I'm not sure it's a real data point. Never a grind. Not once. Always OEM fluids - no exceptions. I don't shift terribly fast; just quick enough not to loose spool.
Old Jul 17, 2017 | 11:08 PM
  #47
2006EvoIXer's Avatar
Okay, so there's more damage?
Originally Posted by kaj
It's never "just a fork".
Old Jul 17, 2017 | 11:14 PM
  #48
LetsGetThisDone's Avatar
The ratio gap + it's only a single synchro is what kills. If Mitsubishi had made it a double synchro, it probably would've been a lot better.
Old Jul 18, 2017 | 06:31 AM
  #49
kaj's Avatar
kaj
Fork break = metal pieces everywhere = chipped gears = ruined trans.
Old Jul 19, 2017 | 04:28 AM
  #50
mines5's Avatar
WTF !! how did it happen ?
Was there any oil in the trans ?
Old Jul 19, 2017 | 05:48 AM
  #51
Gotcha. I didn't think about that. Lol
Old Jul 19, 2017 | 09:47 AM
  #52
kaj's Avatar
kaj
Missing alignment dowel pin caused an off-center clutch disc, resulting in crazy vibration, ending in a fork vibrating itself to death.
Old Jul 19, 2017 | 11:02 PM
  #53
mines5's Avatar
Do you think vibration can cause the fork to brake ?
If fork was vibrating you can feel it during drive and shifts or may be you were more focused on apexes and corners
Old Jul 20, 2017 | 08:04 AM
  #54
kaj's Avatar
kaj
Knocking at idle. Couldn't tell while shifting. I was stumped for two years, trying to figure out what was wrong LOL
Old Jul 28, 2017 | 02:29 PM
  #55
Chrispy0530's Avatar
Reporting back with a small update. Still no issues at all with 5th gear with the Red-Line fluid in the transmission.
Looks like this will get changes with only MT90
Old Jul 28, 2017 | 07:26 PM
  #56
4G63_EVO's Avatar
I use MT-85, but with what you said maybe Ill give the 90 a try and itll help with my notchiness
Old Jul 29, 2017 | 02:11 PM
  #57
mines5's Avatar
Ever tried the Royal purple gear oil ?
Old Jul 31, 2017 | 08:51 AM
  #58
Not gear oil specifically, but I've used their other products. Too over-priced, and for my particular application, I didn't get good results.
My GSX developed rod bearing knock right after switching to that oil, after the car had ran beautifully for years. Could have been completely coincidental, but I do not like how it suddenly started after switching to it from years of using Mobil1/Ams Oil.
Old Jul 31, 2017 | 10:13 AM
  #59
mines5's Avatar
I use Royal purple engine oil 10w40 - works good . Used it in 42C ambient temps, hot humid weather . Never had a problem.
Did not find Red line here so was thinking to switch to royal purple gear oil.
775evo
Jun 18, 2010 01:35 PM
775evo
Jun 17, 2010 03:55 PM
Rez90
10
Dec 29, 2004 04:35 PM
CweSt eVo
Sep 5, 2003 01:49 PM
jman425
May 19, 2003 10:34 PM
