Fp Green 73htz spool time.
Old Jul 17, 2017 | 02:26 PM
  #61
kaj's Avatar
kaj
Originally Posted by e_kobz
71hta
I second this, unless you have no access to e85. The Green will do 350whp on 91oct.
Old Jul 17, 2017 | 04:38 PM
  #62
V.8MR's Avatar
Will have to look into it. Thanx guys!
Old Jul 17, 2017 | 06:30 PM
  #63
e_kobz's Avatar
71hta will do 350whp all day on 91
Old Jul 17, 2017 | 08:14 PM
  #64
kaj's Avatar
kaj
My tune may have been too conservative. I had it tuned to beat the crap out of.
**edit: looked back and maybe I was at 350-360whp. I didn't think it was doing that much on pump. Man, what a fun turbo.
Old Jul 17, 2017 | 11:15 PM
  #65
LetsGetThisDone's Avatar
My 9 turbo made 350whp on 91 with S2's lol
Old Jul 18, 2017 | 05:42 AM
  #66
2006EvoIXer's Avatar
Bubbles from the soap settling or like a stream from leaking air?
It would be REALLY weird to have air coming out of it.
And it can't be coming out of suction coupler. Take a picture next time. Hopefully it isn't a cracked compressor housing.
Old Jul 18, 2017 | 05:59 AM
  #67
romogst's Avatar
I'm seeing a little bit of oil in my compressor wheel side on my DBB FP GREEN MHI anyone else ? I have a Buschur Catch (6AN lines) Can setup and running a Speed Density Intake. Any way of eliminating this problem?
Old Jul 18, 2017 | 06:27 AM
  #68
kaj's Avatar
kaj
Suction coupler?
I keep forgetting I always run small cams and super safe, so my numbers are always lower
That and it's been a while.
Old Jul 19, 2017 | 05:27 AM
  #69
Suction coupler?
Compressor side silicone hose coupler? I'm not sure of the name, but I'm trying to refer to the turbo suction side connected to the air filter. Having bubbles under the name plate doesn't make sense unless housing is cracked somewhere. Maybe that is a solution to help with the surge? Lol
Old Jul 19, 2017 | 05:31 AM
  #70
You probably need a bigger AN to your catch can. Maybe add another catch can on the PVC line too (replace to bigger AN than the tiny PVC size). Is the oil dark color?
Old Jul 19, 2017 | 01:20 PM
  #71
Erik@MIL.SPEC's Avatar
My OG Green (about 10 years ago) made 333whp on the GST Mustang Dyno on 91 and only 21-22 pounds of boost. That should be 370 - 380whp or so.
Old Jul 19, 2017 | 05:12 PM
  #72
Justin Joy's Avatar
Just installed my new rad because the stock one started to leak at the seam and I saw this. Not looking good. I don't under stand I never ran it with no filter. Not sure how something got in there.
Old Jul 19, 2017 | 11:40 PM
  #73
e_kobz's Avatar
That would certainly cause some issues
Old Jul 20, 2017 | 05:06 PM
  #74
How careful are you when you separate the air filter and hose to your turbo? Did you clean the entire area before taking the turbo intake hose/pipe and filters apart. And be even more careful assembling while keeping dirt out?
I think everyone will see this on their blade eventually. I have about 1,000 miles on my HTA71, but I won't be surprised to find at least 1 tiny chip. We'll see when I clean my air filter again when I change my oil.
silverflyer
Jun 2, 2020 08:42 PM
silverflyer
Sep 4, 2018 02:51 PM
TrendSetter
Jan 18, 2016 05:15 AM
