EVO IV Transmission specs
Old Jan 7, 2018 | 02:24 PM
aggieEVO's Avatar
Hey All,
About to tackle some work on the Evo. My clutch is toast, so it's time to dig in. She's my daily driver so I can't have the downtime. I'm considering buying an Evo IV engine/trans set as the price isn't much more than just the trans from the VIII. Then I'd have a block/head to play with or sell to recover some funds.
I know the IV trans will bolt up (and the transfer case is useless). My question is mainly gear ratios. I use Tephra V7 with gear based boost and want to make sure I can bolt this up with no tuning issues. I would probably
I'm still on the fence about this, just gathering information.
Brady
Old Jan 7, 2018 | 02:41 PM
Dakota Evo's Avatar
evo 4 to 6 have an awesome tranny it has the Evo 9 first gear.
Evo 4 engine sucks though I would stay away and just buy a nice used short block. Evo 4 are very weak.
Old Jan 7, 2018 | 04:34 PM
aggieEVO's Avatar
I would really just be using the IV engine for the block and head. I wouldn't be using the internals. Same block and head, right?
Old Jan 7, 2018 | 08:26 PM
Bladey's Avatar
The head is the same, the block is different and is prone to crank walk, so I would avoid spending any money on the block
Old Jan 8, 2018 | 05:40 AM
aggieEVO's Avatar
Is it the block or the crank?
Old Jan 8, 2018 | 03:46 PM
LetsGetThisDone's Avatar
How did needing a clutch turn into buying an engine and trans from another car? lol
Old Jan 9, 2018 | 06:16 AM
aggieEVO's Avatar
Local JDM importer sells IV engine and trans sets for a couple hundred more than I can find just a trans from a VIII. Seems like a bargain
Old Jan 9, 2018 | 07:41 AM
Why do you need a trans though?
Old Jan 9, 2018 | 11:25 AM
aggieEVO's Avatar
Bearings need replaced, several gears grind and I'm sure the synchros need replaced. I bent the 3-4 select rod last time I had it apart. 5th gear splines on the I put shaft are worn.
Old Feb 23, 2023 | 08:26 PM
KaKaSHii1210PR's Avatar
CM2A awd with CP9A manual transmission?
So im not trying to build an evo but i woul love to know if i need to swap transfer case for cp9a transmission? I have the cm2a/ mx saloon but is automatic, although i wanted to make it manyal idk what transmission ill need.
seankhan
49
Nov 26, 2019 01:43 AM
eusgen
Lancer Tranny/Drivetrain Tech
Sep 29, 2013 06:53 PM
testa corse
Aug 14, 2011 02:04 AM
Pro
Sep 18, 2007 02:15 PM
be12nard
Mar 11, 2005 09:15 PM
