Manley Billet 100mm crank - Cracked
Old May 10, 2018 | 06:44 AM
  #91
2006EvoIXer's Avatar
Originally Posted by xRoguex
Manley responded - and will warranty the crank. They are shipping me a brand new billet crank.
It will be balanced(along with the full assembly) and it will spend its whole life with a fluidampr on it.
That's awesome that a manufacturer stands behind their products.
Old May 10, 2018 | 07:14 AM
  #92
Don
Imagine if they covered the installation labor & the shipping cost involved in returning the failed crank
Old May 10, 2018 | 08:02 AM
  #93
Teal2nnr's Avatar
those are talking about 88mm, not 100mm.
My bad. Im glad they're granting warranty on your crank.
Old May 10, 2018 | 10:59 AM
  #94
Don
true, but these billet cranks are $1300. They could easily say it's 8 years old and anything can cause the failure and leave you hanging. So yes, there were labor costs. But OP doesn't need to buy another crank.
Old May 10, 2018 | 11:28 AM
  #95
Just thinking out loud:
Its very likely Manley has investigated this failure & have accepted that many of these failures are their responsibility
They are providing a "parts only" contribution to limit their financial exposure. Id bet their true cost on that crank is $400-450
Old May 10, 2018 | 12:49 PM
  #96
But are these failures limited to just on Manley cranks? I thought othet brands failed the same way.
Old May 10, 2018 | 12:58 PM
  #97
Don.
RS Motors told me,
"They all fail"
But, RS & other builders seem to have flocked around the Eagle & K1 brands as the top shelf cranks
Old May 10, 2018 | 01:02 PM
  #98
Eagle is probably for price value. If they fail at the same spot, that means everything else is overbuilt.
Old May 10, 2018 | 01:14 PM
  #99
Don
I would gladly pay $500.00 to $1000.00 more for a crank if I knew the quality & robustness was there. With one crank failure, you have lost $$$thousands$$$
Old May 10, 2018 | 01:44 PM
  #100
Don
We all do. But the problem is we don't have all the statistics. How many failed vs how many are still running? Manly could have the most total failures but if we know how many are running out there, they could have the least % of failures. Nothing is clear cut.
Also, I now see how damper actually helps crank at #4 rod. I'll share later since it's going to take time to explain.
Old May 10, 2018 | 01:51 PM
  #101
Pal215's Avatar
Nice ideas guys, I agree with much of what was said.
Something I always wonder about....
If we are looking at a crankshaft from the top, the power generated from pistons/rods 1,2, and 3 is transferred to the flywheel side of the crank through rod journal #4. ALL(minus friction losses and windage) of the power coming from 75% of the engine has to pass through that sorry little rod journal #4 before it can get to the final main journal and then the flywheel, at which point we can send it. Rod Journal #4 is also responsible for absorbing and transferring the power generated from piston rod assembly #4. The main journals are already thick as hell in diameter and have no trouble transferring the power of the adjacent cylinders through the crank, but how can we rely on one much smaller rod journal to do the same job?
Compare it to a gauge change in a wire. If you have someone using 0 gauge wire to send 150 amps into a room, but uses 20 gauge wire of equal length to connect it to the load, you're going to obliterate that 20 gauge wire if the load needs the full current. We are asking a lot of our cranks.
It's almost as if the rod journals would have to get progressively bigger as they approach the flywheel side in order to truly carry the power generated by the previous cylinders. The problem with this is that it puts the crank WAY out of balance and you would have to notch cylinders 2,3,and 4 to clear the larger piston rod big ends that would be needed lol. Thus, the solution was to build the crank out of a material strong enough such that the rod journals 1, 2, and 3 are over-engineered (stronger than what is needed) and #4 is good enough.
Solution: I think OEM crank, keeping it under 350 wheel trq,,,but that's not very fun now, is it?
I would hate to be a rod journal #4.
Old May 10, 2018 | 01:57 PM
  #102
Good start. I'll add more later to make things worse for #4
Old May 10, 2018 | 02:21 PM
  #103
Pal215's Avatar
I look forward to it!
Old May 10, 2018 | 02:23 PM
  #104
I'm not sure if I'll post here and derail this thread. Maybe I'll start a new thread.
Old May 10, 2018 | 03:27 PM
  #105
LetsGetThisDone's Avatar
The simple solution is to not run 100mm cranks. Especially not in a 4g63 block.
