Manley Billet 100mm crank - Cracked
Old May 27, 2018 | 11:33 AM
  #136
2006EvoIXer's Avatar
Originally Posted by CBRE
Manley I beams are made here, I used Carrillo in my personal build and always recommend them, Chinese made parts should not be used in any internal combustion engine. As far as cranks OEM or Callies cranks, I refuse to use or recommend Manley junk.
Taiwan has better quality control by a long shot over China!
I'm looking into Callies cranks. Where can I get more info on them?
Old May 28, 2018 | 12:32 PM
  #137
Kevin Troy's Avatar
Here is my Manley billet crank (190120BPL) and the hole design. pic is from Norris Designs build in October 2014.
if it helps to somebody :-)
Old May 28, 2018 | 12:36 PM
  #138
Kevin Troy's Avatar
when comparing directly, they do not look the same nor the design...
It's the 100mm stroker crank. Also fluidampr fitted
image hosting over 5mb
Old May 28, 2018 | 01:37 PM
  #139
Oil opening looks centered here (although hole under still makes the right side weak). But it is better than oil opening closer to right side. They should have cut the tear drop further to the left because the oil passage is under on right. Personally, I'd prefer tear drop rotated 90° clockwise. As crank twists, oil would flow better with tear drop going to right instead of left.
Old May 28, 2018 | 10:12 PM
  #140
xRoguex's Avatar
Yeah unfortunately OEM isn't strong enough for me in a 2.4 platform.
I think once we magniflux it, micor polish it, and balance it, it will be fine.
Old May 28, 2018 | 10:46 PM
  #141
Ayoustin's Avatar
I talked with Manley in December 2017 so it's definitely not a revised version.
Old May 28, 2018 | 11:34 PM
  #142
Kevin Troy's Avatar
I'm sure they had a reason and R&D on why the oil openings are designed, engineered and manufactured this way.
I'm no engineer but how are other crank oil openings designed? different?
Besides the micro fracture on OP's Crank which has 30,000 miles (don't forget that!!!), how many of these cranks are out there which have failed completely? like broke in half etc.etc.
Old May 29, 2018 | 07:09 AM
  #143
Ayoustin's Avatar
They can be drilled differently and at different angles, chamfers can be changed as well too.
A fair amount of people have posted up about broken Manley cranks but up until now all the ones I've seen were forged, not billet. Also pretty much all of those guys are pretty hardcore track guys that definitely put the car through its paces. A lot of track guys have also cracked factory cranks as well so it's definitely not an isolated issue with just Manley. Keep in mind that we don't know how many cranks Manley sells vs other companies so we can't really say for sure that other manufacturers don't have this cracking issue on rod journal #4.
With that said, it seems like most guys have had the best luck with the K1 billet stuff.
Old May 29, 2018 | 06:21 PM
  #144
hutch959's Avatar
k1 billet what english uses.
Old May 30, 2018 | 08:04 PM
  #145
xRoguex's Avatar
did they indicate to you that they had revised them?
Old May 30, 2018 | 10:40 PM
  #146
Ayoustin's Avatar
At that time they had told me they had a new version with a stronger design due to a revised oiling hole and it was still under testing at that time. I have not talked to them since so I have no idea when they plan to release said design.
Old Jun 7, 2018 | 01:26 PM
  #147
xRoguex's Avatar
Came back from the machine shop - 6 grams out of balance.
I dont know if thats good or bad, but it is now perfect.
Old Jun 7, 2018 | 02:34 PM
  #148
Close up pictures of all the oil ports would be nice. If not all, then just the #4
thanks!
6 grams on a crankshaft doesn't sound like much.
Old Jun 8, 2018 | 01:20 AM
  #149
Kevin Troy's Avatar
You are talking about the new crank you have received from Manley, right?
Old Jun 8, 2018 | 09:13 AM
  #150
LetsGetThisDone's Avatar
Idk about manley, but Eagle states their cranks come +/-2% and need to be balanced. 6 grams is not a lot on 30lb+ crank.
