Manley Billet 100mm crank - Cracked
Old Oct 8, 2018 | 05:12 AM
  #196
2winscroll's Avatar
Originally Posted by ayoustin
Having a sharp edge on the oiling hole creates a stress riser. Stress risers greatly increase the likelihood of a cracking forming. Once a crack forms, even at a microscopic level, it will continue to grow until it reaches the other side. In this case the other side would be the other side of the journal.
Amazing!
Old Oct 8, 2018 | 05:26 AM
  #197
Ayoustin's Avatar
Originally Posted by 2winscroll
Amazing!
Was explaining it for those who don't have the understanding as to why. Thanks for the sass.
Old Oct 8, 2018 | 06:13 AM
  #198
Good post & good info
Yeah, im sure most are not familiar w/the term "stress riser". I work in the mechanical industry, so we reference those techniques as general practice
Old Oct 11, 2018 | 07:29 AM
  #199
LetsGetThisDone's Avatar
Kaboom.
Hard to tell from pic, but it doesn't look like this one started at the oil port pictured on the rod journal. May have been on the other side.
Old Oct 11, 2018 | 07:41 AM
  #200
Abacus's Avatar
Kaboom.
Nothing is indestructible.
Two sides to every story. Maybe that engine had been rattled for a long time. Occasionally pump gas, timing and high boost get out of hand . Or its an auto x car that shakes the tires 100's of times with a QM. RS motors broke a few STOCK cranks with that setup. Eventually the weakest link will break. Big tires, built diff's, a strong clutch and a loose surface is a hard environment.
FWIW, TS comp has used 100's of the old style 100mm billet cranks for years with a high success rate. If he was running into issues, He would most likely chose another route.
Manley made the change recently and it should add even more strength . However, tuning and environment are still relevant IMO.
Old Oct 11, 2018 | 08:43 AM
  #201
2winscroll's Avatar
Maybe they should change their name from SLOWMOTION MOTORSPORTS to NOMOTION MOTORSPORTS?
Who in their right mind would name a performance shop Slowmotion Motorsports?
There’s another oil hole on the other side of the journal so it’s impossible to tell if that was the cause. I guess you could call them and ask?
Old Oct 11, 2018 | 08:50 AM
  #202
2winscroll's Avatar
Actually it does look like it came from the oil hole. If it would have cracked on the oil hole facing the camera it would have broken on the other side of the journal.
Old Oct 18, 2018 | 08:01 PM
  #203
xRoguex's Avatar
so what would be the accepted method for removing the razor sharp edge? Can it be done by hand or is this a machine shop only deal or?
Old Oct 18, 2018 | 08:55 PM
  #204
Smooth it out with a small bit on a dremel
Old Oct 20, 2018 | 02:52 PM
  #205
Kevin Troy's Avatar
Nothing a dremel can't do.
by doing that, be precise and sober
Old Oct 20, 2018 | 05:52 PM
  #206
Absolutely hahaha
Old Nov 26, 2018 | 02:23 PM
  #207
2006EvoIXer's Avatar
For those of you who don't know Robert Garcia of So Cal, there is no Evo that can hold up to his abuse. Lol
Anyway, this is his Manley billet 88mm crankshaft oil journal after 10,000 miles.
Old Nov 26, 2018 | 02:43 PM
  #208
Meanwhile, English Racing uses an Eagle forged 88mm to make 1400whp. Why do they use it? Because it's the only one that doesn't crack out of testing all the cranks at 1100-1200whp+...
Old Nov 26, 2018 | 03:05 PM
  #209
Ayoustin's Avatar
Golly that's a sharp *** edge on that oiling hole chamfer. I'd be curious to see what they look like on the Eagle stuff.
Old Nov 26, 2018 | 03:16 PM
  #210
This guy runs his evo like no other. He uses antilag and launches on slicks. He blew up 3 or 4 FP Zeros. Lol
Nothing holds up to his abuse. Nothing!
