Manley Billet 100mm crank - Cracked
Old Jul 9, 2018 | 09:15 PM
  #166
2006EvoIXer's Avatar
Here's K1 Billet crank.
Old Jul 9, 2018 | 09:22 PM
  #167
This is close up of 2nd picture.
Old Jul 9, 2018 | 09:24 PM
  #168
Oil ports are more direct than Manley ports. Manleys will force oil into rod bearings better at the cost of weakening the journal bearing against fracture.
Old Jul 9, 2018 | 11:03 PM
  #169
LetsGetThisDone's Avatar
That looks like OEM style oiling. Is there a hole on both sides of the rod Journal? And threaded plugs on one side of the web? That's how the eagle forged cranks are..
Old Jul 10, 2018 | 12:21 AM
  #170
Sorry, I boxed it back up. It (surprisingly) looks very much like OEM. Make me wonder why I paid extra for this?
Old Jul 10, 2018 | 12:25 AM
  #171
I thought all cranks has holes on both side of journal. K1 does. You guys with the Manley billet cranks, I thought one of #4 rod journal oil ports was installed backwards. I thought I saw both teardrops facing each other instead of in same direction.
Old Jul 10, 2018 | 02:25 PM
  #172
What meant does the hole go "through" the rod journal?
Old Jul 10, 2018 | 02:34 PM
  #173
Oh! I didn't look through the hole. I'll check tonight, now that you got me curious.
Old Jul 15, 2018 | 08:40 AM
  #174
Just checked. Yes, every rod and main journal oil port goes through! Is this normal of all cranks?
Old Jul 15, 2018 | 10:34 AM
  #175
kikiturbo's Avatar
there are two methods of drilling a crank oil passage..
the stock crank has such holes that go trough the journal and those are connected to the main bearing with a hole that goes from the outside of the big end right into the middle of the main journal. This means that you ahve to cap that hole on the outside of the big end and leaves more room for dirt to gather inside the oil holes..
The other method is straight shot oiling and there you have these holes that go directly from the big end journal right down to the main bearing journal. As a consequence of the angles involved you get oval holes on the big end which seem to be a stress point. It was long been considered that the straight shot oiling was better, but as we see, if it is not done correctly you get stress raisers..
Old Jul 15, 2018 | 10:52 AM
  #176
What do you mean cap? We need to plug a port?
Old Jul 15, 2018 | 12:11 PM
  #177
Yes. The OEM crank has ball bearings pressed into the hole. The eagle has threaded plugs.
Old Jul 15, 2018 | 01:21 PM
  #178
kikiturbo's Avatar
not you but crank manufacturer...
Old Aug 9, 2018 | 11:20 PM
  #179
xRoguex's Avatar
... well shes spinning..
Last tune by TSCOMPUSA was 701/565.
Lets see how long she stays together this time!
Old Aug 10, 2018 | 09:29 AM
  #180
Hopefully this new oil port was polished up to prevent fracturing. I couldn't see a difference from the pictures, but your pictures didn't show a closeup of the oil ports. GL!
