ETS Quick spool Turbo kit(G30)
Old May 7, 2020 | 08:39 AM
  #226
Abacus's Avatar
Originally Posted by 240Z TwinTurbo
Post 214 above shows back to back runs using the new MIVEC values during spool with the only difference being I ran negative cam timing above 7000 RPM.
Below is the requested street runs before and after MIVEC changes during spool.
Thank you
Old May 9, 2020 | 09:41 PM
  #227
SnailSpeed's Avatar
Originally Posted by Abacus
Hard to believe it comes up harder then both our cars but times do change.
Nice to know there are other options out there that perform this good.
Great job on building that engine /setup Sean.
One big downside for me would be the exhaust note change if I went the Garrett direction. Going away from the Stock location manifold tends to sound more Honda.
I hate the sound of an equal length manifolds too. Could always have someone make a custom manifold with unequal length runners so it would sound somewhat similar to stock. How much power would be lost idk but the fp cast manifold has been taken pretty far on zeros and is very far from equal length.
Old May 15, 2020 | 02:27 AM
  #228
RSMike's Avatar
Originally Posted by Construct
What data logging software is that?
I'm using an Emtron KV8. It's just a boost vs RPM scatter graph, very easy to do on my setups.
Old May 15, 2020 | 11:35 AM
  #229
LetsGetThisDone's Avatar
I would not be interested in sacrificing performance for sound. Its one thing to have a stock frame turbo and use the FP cast manifold as it does work well. But if spedning the money to move to a turbo kit, I'd like it to be optimized for performance.
I should be able to get spool up results in gears 1-3 and maybe 4th this weekend. Going to be getting the car buttoned up to go back to the owner.
Old May 16, 2020 | 04:20 PM
  #230
As promised, logs of the spool up in 1-4, and also a 1-4 rip to show transient response. It honestly feels identical to the MHI FP red when it was on my stock engine (non-mivec 2.0, S2's). This car is a non-mivec 2.2 with S2's.
First one has the 1st, 2nd, ad 3rd gear log files, 2nd one has 4th gear and the 1-4.
https://datazap.me/u/letsgetthisdone...2-3&hg=1-1-2-3
https://datazap.me/u/letsgetthisdone...3-4&hg=1-2-3-4
@RSMike
Old May 17, 2020 | 02:47 PM
  #231
deylag's Avatar
Yea I reviewed the logs and the turbo does spool up fast. I believe the data shows that the transient response from vacuum to full boost is averaging a little under a second between most shifts.
Old May 17, 2020 | 03:02 PM
  #232
I was gathering .3-.4 second boost recovery.
Old May 19, 2020 | 08:56 PM
  #233
deylag's Avatar
Yea that's a better estimation. Were the pulls done using NLTS?
Old May 19, 2020 | 09:11 PM
  #234
No, that's regular old lifting to shift.
Old May 19, 2020 | 09:38 PM
  #235
Dallas J's Avatar
Veteran: Army
Granny shifting, not double clutchin like you should...
Old May 19, 2020 | 10:07 PM
  #236
Hahaha
Old May 20, 2020 | 06:27 PM
  #237
RSMike's Avatar
Cool - thanks for the info.
So your 20psi boost threshold in each gear is around:
1st - 5350rpm
2nd - 4550rpm
3rd - 4100rpm
4th - 3850rpm
For comparison - mine with the TD06-20G sized turbo and twin scroll (which will make much less power than yours) is:
1st - 5500rpm
2nd - 4000rpm
3rd - 3200rpm
4th - 2850rpm
(for same 20psi boost level)
Old May 21, 2020 | 03:16 PM
  #238
1st - 5350rpm
2nd - 4550rpm
3rd - 4100rpm
4th - 3850rpm
1st - 5500rpm
2nd - 4000rpm
3rd - 3200rpm
4th - 2850rpm
Where is makes 20psi really doesn't matter. Where it makes 300ftlbs on a dyno is whats important. So not having a dyno sheet to see what torqwue # that 20psi correlates to, the data becomes vague.
Old May 21, 2020 | 09:32 PM
  #239
Dallas J's Avatar
Veteran: Army
I feel like I invented this, but I probably did to myself. 300ftlbs is such a good number for us because once you hit that your moving fast to whatever RPM you need. So I totally agree, I look at 300 ft-lbs rpm more than anything in response.
Old May 21, 2020 | 10:10 PM
  #240
I do think I picked it up from you, or it was at least from this forum. But it has held very true since I started paying attention to it years ago.
