ETS Quick spool Turbo kit(G30)
Old Apr 5, 2020 | 08:51 PM
  #121
LetsGetThisDone's Avatar
Originally Posted by RWD4G63
I'm still hoping the T4 divided housings come out soon.
We will see. Garrett doesn't even offer those for gtx 30r and gtx 35r turbos. I think ATP does them.
Old Apr 7, 2020 | 02:22 AM
  #122
ConEvo's Avatar
Originally Posted by mines5
Will be waiting to see the results.
By looking at the specs i am still confused to which turbo it is comparable with
6466, 6266 or any 800 hp capable EFR series.
From horsepower view, it seems that the G30-900 is similar with 6466, always referring in Garrett power output. The next smaller turbo that Garrett offers, is the G25 which has 660hp. I think the 6266 falls somewhere between those two turbos.
In my opinion the G30-900 will struggle to make 900whp like 6466 do. However i believe a G35-900 would be easier to achieve that or even make more power than a 6466. Also, i believe that those new turbos would be more responsive than pte equivalent units or gtx series, so it will be a win-win case if it meets our expectations and advertised power output
Old Apr 7, 2020 | 09:24 AM
  #123
There is a g30-660 and g30-770.
Old Apr 7, 2020 | 10:34 AM
  #124
ConEvo's Avatar
correct, i totally forgot about these
Old Apr 8, 2020 | 10:18 AM
  #125
Grimgrak's Avatar
Anyone see any results in single turbo application for the g30 900?
Old Apr 10, 2020 | 05:55 PM
  #126
Grimgrak's Avatar
Also if the g30 770 is replacement for the gen2 gtx3071 does it spool any better?
Old Apr 10, 2020 | 09:03 PM
  #127
spdracerut's Avatar
I don't know about spool better, but it flows 10lbs/min more! Look to the G30-660 if you want better spool and equal power to the gtx3071r gen2. Of course, the G-series uses MarM for the turbine wheel which has a much higher temp limit than the inco wheel in the gtx = more power.
Old Apr 10, 2020 | 10:19 PM
  #128
It's not really a "replacement". The Gseries is an entirely different turbocharger line than the GTX.
Old Apr 13, 2020 | 05:41 PM
  #129
Grimgrak's Avatar
Was told the g30-660 is replacement for the 3067
Old Apr 13, 2020 | 09:04 PM
  #130
spdracerut's Avatar
Wheel size for wheel size, yes. They both have 60mm turbine and 67mm compressor. But both the turbine and compressor wheels are of different design. And the G-series turbo is basically all new too. Well, it came out 2.5 years ago.
https://motoiq.com/nerd-o-scope-hone...turbochargers/
Old Apr 14, 2020 | 05:22 AM
  #131
Nicolas's Avatar
Haven't quite understand what is its market segment since for every Gseries there is a gtx2 series that does the same
Old Apr 14, 2020 | 07:41 AM
  #132
Size for size the g series out flows the gtx2, and the wheels are lighter, which means they spoil faster and have better response.
Old Apr 14, 2020 | 09:13 AM
  #133
Nicolas's Avatar
is there any link with back to back dyno test between the 2 series?
Old Apr 14, 2020 | 10:24 AM
  #134
There's barely any gseries results. If you find one, post it here.
Old Apr 14, 2020 | 11:44 AM
  #135
Nicolas's Avatar
unfortunately i had no luck on my researches the last 3-4 months. On the other hand if it was as good as they say there would be results all over the place
