Backfire. Tune? Injectors?
When I'm at low-speed, low-RPM and floor the gas pedal for a bit and let off, sometimes the car backfires. If it shoots out a fireball, then that's cool.. but I have no idea, so...
Would this be tune related? A leaking injector, maybe? Evo IX tuned on FlexFuel, 1050 injectors, Walbro 255. My tuned is locked, so no way to see what's going on there. I don't want to bother my tuner unless I can confirm it's the tune.
I don't drive the car much.. so memory is fuzzy. I've been on e85 for a long time and don't think it did it then, but now I'm on pump gas and it is. So, that should mean tune? Unless the injectors somehow were affected negatively while sitting/occasionally driving with e85. I guess I need to put e85 in it again and double check if it still happens.
I know FF is just a bunch of interpolation between values....so maybe it's just a "glitch" in the system...?
If you're below E20ish and above E70ish the tune is operating 100% on the pump gas or E85 maps respectively.
But it sounds like a slight tune different is likely what's causing it. Likely the decel fuel cut needs tweaked.
Unless there's other drivability or AFR issues I wouldn't think it's the injectors or something mechanical.
Problem solved.
