Fixing the Evo Oil system - External Oil Pressure Regulator. Why and how?
Old Dec 18, 2022 | 02:17 PM
  #91
RSMike's Avatar
Originally Posted by EvocentriK
Thanks for that. So if the stock oil return hole is unplugged, does oil continue to return to the back of the pan in the stock location as well as via the new front of pan return system?
Also I asked this elsewhere but I'll put it here to consolidate - the pans stocked by Benny at Benchmark all have additional NPT ports next to the oil drains. I don't need this, I have an oil temp/pressure sensor in the housing already. Are the pans available without these additional ports?
The system and fittings are engineered to work correctly. It blocks off the OEM drain port.
No, all pans come with the 1/8NPT ports and they come with a bung if you dont want to use them.
RSMike
138
Jul 20, 2025 09:19 AM
awdboosted
Sep 11, 2017 01:31 PM
RalliartPro
May 21, 2009 11:47 AM
matej
Sep 15, 2008 04:07 AM
RyanM
Oct 27, 2004 08:46 PM
