BW S366 SX-E (6668) TwinScroll Experiment
Old May 8, 2020 | 04:20 PM
240Z TwinTurbo's Avatar
Previous build and dyno results can be found below.
https://www.evolutionm.net/forums/ev...l-project.html
https://www.evolutionm.net/forums/ev...-pump-gas.html
I don't normally do this, but I am changing my setup to try something new starting tomorrow and car is already on the lift. I am by no means unhappy with the current setup and it really is fun to drive, but a crack in the manifold requires a change. I will still be running a T4 TwinScroll with the same 1.00 a/r turbine housing, but I had AGP send the S366 with the 68mm turbine wheel so I can use it with my existing housing. The larger compressor goes from 76lbs/min with the 62mm wheel to 87lbs/min with the 66mm wheel so about another 100hp worth of flow. The other change I will be making is the wastegate dumps will not be recirculating, which I hate. While this will not be part of the initial efforts, I also ordered a 4.08 final drive from Jacks along with the EVO 8 5th gear set. So just to recap here are the changes...
  • S366 SX-E (68mm turbine option)
  • Non recirculating wastegates
  • New PCV setup with AC Delco electric pump
  • Changing front motor mount to something more compliant
  • 4.08 final driver (after initial results)
  • EVO 8 5th gear (after initial results)
Old May 8, 2020 | 05:14 PM
Grimgrak's Avatar
For a supposed garrett guy u sure do favor the BW's.
Old May 8, 2020 | 05:20 PM
the bw is tough, cheap, and performs well. Besides, Garrett doesn’t currently have a T4 TS option I care to have.
Old May 9, 2020 | 12:30 PM
Old May 9, 2020 | 05:01 PM
The vband flange I had machined did not arrive today so I’m kind of stuck because I need to fab the downpipe before doing the wastegate dumps.
Old May 11, 2020 | 12:57 PM
The vband flange I had machined arrived today, but the ultra tight radius 90deg bend (0.84d) was not so "ultra" and was actually 1.06d. Damn ebay scammers! Had to reorder from original source at a higher price so it won't arrive until Friday. I will focus on mounting the Delco vacuum pump until the UTR 3" bend arrives.
Old May 12, 2020 | 01:27 AM
KingTal0n's Avatar
how are you going to measure/log crankcase pressure data?
What pressure drop are you hoping to achieve?
Stock for most engines is a couple inches of mercury say 20" H2O
Old May 12, 2020 | 02:52 PM
The UTR 3" pipe arrived in one day! Downpipe complete (minus O2 bung) and sometimes you just get lucky when cutting the pipes!
Old May 13, 2020 | 01:52 PM
One down, one to go!
Lower IC pipe redone!
A little 4.08 action arrived today!
Old May 13, 2020 | 01:54 PM
SWOLN's Avatar
Curious about that Delco Vacuum set up. Dealing with some decel white smoke rn.
Old May 13, 2020 | 02:48 PM
ctfpevoVIII's Avatar
You do some nice fab work !! Curious to see your new results!
Old May 13, 2020 | 05:14 PM
I’ll discuss everything once I get to that point, which should be soon.
Old May 14, 2020 | 09:26 AM
Old May 14, 2020 | 11:09 AM
Old May 14, 2020 | 11:28 AM
LetsGetThisDone's Avatar
After all these years of always running recirc gates, I'm surprised to see you go external.
The new kit looks good. Looking forward to results!
