Act New Twin Disk Who Running One?
DM me on price
I'm now locked out of all gears while the car is started. Slave cylinder moves when depressing the clutch. Going to readjust the clutch pedal to see if that fixes it, if it doesn't, I'll be dropping the trans to inspect the ACT twin.
How far off the floor does your clutch engage? It prob wore and is now to far out. Will it go into gear while car is off? If it does and you try to start the car if the car moves forward you need to adjust the pedal towards the floor
Before it would engage about halfway up on the travel. It goes into gear just fine when the car is off. The car now tends to jump very slightly when depressing the clutch to start. Hoping it's just an adjustment.
Pretty much almost maxed out the clutch pedal adjusting and I'm slightly able to get the car into gear.
I've been daily driving it since install in December 2020. I ran into the lockout issue last winter on start, but it went away and I didn't experience it this winter.
Shouldn't matter its a known problem with the clutch itself but I am sure you would have to find out what the build date is and or send them a pic of the damage. I have had mine for idk how long and they sent me a warranty info and mine has like 13k on it.
