Act New Twin Disk Who Running One?
Old Oct 22, 2024 | 12:42 PM
  #256
staywide8's Avatar
Originally Posted by CurseDSM
Then go to exedy. Last time I checked at cost to rebuild a triple being I have family there was 1800. Discs for the act are like 150 each so IDK where your getting that price. You only replace intermediate plates if they are done and need to be replaced.
And just so you know extreme psi sells full rebuild kit plates and all for 600 and some change. Idk where u get your prices from but it's pretty obvious you don't look very well for things you wanna replace. Idk if that's the one you run but took me all of 3 seconds to find.
$2,113.18 is the parts rebuild cost on the triple, without a pressure plate. You can get a pretty serious twin for that price.
Old Oct 22, 2024 | 12:54 PM
  #257
CurseDSM's Avatar
You must have missed the part where I said I have family that work there and I get it at cost. So 1800 is basically cost. And why pay that much when I can run this twin and will be way easier to drive and keep my drive train from exploding.
And I will add this is prob the best clutch I have used on the street. It isn't a race only clutch like Exedy, Quartermaster, Tilton, and comp. This is built for the street why I have organic discs in my car. Sure if i wanted to run it on the strip I would go back to an Exedy but why? Light pedal, good for 850 crank tq and easy to drive.
Old Oct 22, 2024 | 01:01 PM
  #258
staywide8's Avatar
Sure, but that doesnt help anyone else but you. I have an exedy triple now. Its ok. Wore fast. Going to a xclutch twin next week. I dont think for the amount of life you get that unless you had too, I'd go exedy triple again. All have caveats though.
Old Oct 22, 2024 | 01:10 PM
  #259
CurseDSM's Avatar
I agree with you 100%, not everyone has family discount. And If you look at x clutch and the act there pretty much the same design. I have a buddy who has used both of them and he was like really isnt a difference driving them. So really what are you saving by going to them? But to each their own. I know I looked a x clutch last year at the shootout and even seeing them both myself I am not convinced one is better then the other. There is to many similarities.
Old Oct 22, 2024 | 11:28 PM
  #260
VeebeeIX's Avatar
I contacted STM and ACT directly for this.
STM said they dont keep rebuild parts, and had to go ACT direct, which is what I did.
Old Oct 22, 2024 | 11:45 PM
  #261
VeebeeIX's Avatar
in your 3 seconds did you find the correct part ? i think not from what I see online...
https://www.extremepsi.com/store/ACT...-and-Post.html
that rebuild kit is not for the Twin Mod kit.
Old Oct 23, 2024 | 06:52 AM
  #262
CurseDSM's Avatar
Nope I just hooked for act twin rebuild kit. I was going into tharapy when I posted it. Point is if you look you can find.
https://www.advancedclutch.com/t1s-rk10-act-mod-twin-225-sprung-street-lvl-1-disc-rebuild-kit
There just like thst. Again idk the part # off the top of my head but you can find them easily
Old Oct 24, 2024 | 07:42 PM
  #263
krys88's Avatar
Ok so question for guys that run Act twin clutch. What I am wondering about is how is shifting at high rpm on act twin? Are gears going smooth at 8500-9000rpm? The reason why I am asking, because I went with a lot of clutches from Act single, Exedy twin, competition twin to finally Quartermaster twin. All clutches had some issues with fast shifting at high rpm's except quartermaster. I have build trans and only quartermaster shifting perfect on any rpm I want. I can shift at 9200rpm with no single issue. How does Act twin perform with high rpms?
Old Oct 25, 2024 | 08:31 AM
  #264
CurseDSM's Avatar
I can't really answer that being I have version 1 of the pressure plate. But I'm sure if adjusted correctly it should shift. That seems to be the problem though is they all lock out at high RPMs.
Old Oct 25, 2024 | 08:32 PM
  #265
krys88's Avatar
Does your version 1 have trouble with shifting at high rpms? I am wondering how's version 2, maybe somebody here will respond. My other clutches had issues with high rpm shifting, but quartermaster is doing it's job very well, but it is not friendliest clutch on the street.
Old Oct 26, 2024 | 08:02 AM
  #266
CurseDSM's Avatar
Yes it locks me out at 9k. Act did a revision to help that and for the tabs not to break but I don't have that version so I can't comment. I in know I ride my clutch pedal closer to the floor then most which maybe my problem idk.
Old Oct 26, 2024 | 05:25 PM
  #267
krys88's Avatar
Thanks for help.
Old Oct 26, 2024 | 05:58 PM
  #268
CurseDSM's Avatar
Thanks for help.
Sorry I cannot help you guys out more but that's all I can comment on.
Old Oct 26, 2024 | 08:12 PM
  #269
AWD96's Avatar
Unless you're changing out clutches all within a few hundred miles and not missing a shift in between, it's really hard to say if a clutch is causing lockout. Adjustment, trans condition, clutch lines, fluid etc all have a part to play.
The weight on the input shaft though, will have a huge part to play in high rpm shift quality. ACT spring tabs are to reduce noise and they were a huge issue, the design suggests the potential is there to shift at high rpm, but really what we need is someone to weigh the discs of all these different options! That will tell the story
Old Oct 26, 2024 | 08:30 PM
  #270
CurseDSM's Avatar
Yeah I agree I myself was running Schaeffers 75w140 and it was ok but I have to have the car completely warmed up to get it not to shift like ****. I since went back to 75w90 in the trans and we will see if it will help. Odd thing is the 75w140 flows just as smooth as the 90 but is just thicker. I think I will be ok now that I switched cause when it drops below like 70 degrees thing just doesn't wanna shift
