Act New Twin Disk Who Running One?
Just out of curiosity, when was the last time the master and slave have been changed? And does your lock nut under the dash come loose when you have to adjust it? I ask this cause I had a problem with my old Exedy clutch not wanting to go into and out of gear and it was my damn lock nut coming loose and readjusting the clutch on me. As for the master and slave they could be wearing out if you haven't ever changed them. I am going to plan that when the time is right with mine
Current issues with V2:
Random gear lock out
fork rubbing against pressure plate
For the Torque capacity I'd need, its 2 separate discs and ACT has a splined solid hub that the discs ride on which ultimately decided for me. I dont want the wear on the input shaft associated with 2 discs.
I
Hmm maybe it's the Exedy that it's the same as. I remember looking at one of these and I was like oh it's the same as blank
Wow you guys really have a lot of issues with Act and I was considering switch from my Quartermaster twin. As much as I hate the noise actually Quartermaster 8 leg doing perfect job. Clean shifts at 8500-8800rpm, a lot of launches and I never ever readjusted it because I don't need to. I think I will stay with quartermaster forever heheh, I get use to it that I can be in heavy traffic with no problems.
