Engine stalling
Old Apr 27, 2004 | 10:22 PM
Deca Auto's Avatar
Engine stalling
I have AEM shortram, and Greddy TypeS bov Recirculated w/lower vacuum connect & spring set soft.
Anyways anytime I am cruising 20-50 mph and I put it in neutral the engine rpms shoot down to 150-700 RPMs then most of the time it goes back to 1000 rpms or it stalls.
Also I don't know if this has happened to anyone else but sometimes when I drop my hood to close it w/the engine running the engine stops for like a second, but doesn't die. I figured it was air being forced down the maf through the intake when the hood closes but am not sure.
Old Apr 27, 2004 | 10:27 PM
fr34k's Avatar
yea i got the same problem too with the HKS SSQV USDM version.. which is the VTA version... many times the rpm drops to below 1000 and sometimes it stalls.. any help ppl??
Old Apr 28, 2004 | 10:40 AM
evo_dadi's Avatar
hey deca auto i used to have the aem intake also and it makes my car close to stalling at times.try checking the connections to see if you got any loose fittings there and tighten them all up.
fr34k vta will make your car stall not unless your not on maf anymore like a speed density sensor.heck even with the recirculating kit on the hks bov it still stalls sometimes.get a recirculating kit and that would kinda help with the bov.you can either switch to a forge bov that recirculates already.
Old Apr 28, 2004 | 10:52 AM
turbo4g63's Avatar
Re: Engine stalling
Take out the smaller spring inside the BOV, leave the big one and set it soft.
Old May 6, 2004 | 02:11 AM
cokofellah's Avatar
Also I don't know if this has happened to anyone else but sometimes when I drop my hood to close it w/the engine running the engine stops for like a second, but doesn't die. I figured it was air being forced down the maf through the intake when the hood closes but am not sure.[/QUOTE]
dude, this is exactly what happens to me too....
drop the hood, and the idle drops lower for a second but engine doesn't die.
HKS RS intake and stock blow-off
Old May 6, 2004 | 06:32 AM
GOKOU's Avatar
I have the same problem!!!!
People keep saying it' the BOV so I'm changing the Turbo RFL bov to the 1g bov. I'll let you guys know if this solves the problem.
Anyone having this stalling issue with a stock CAR????
Old May 19, 2004 | 09:11 PM
players234's Avatar
I have the Aem short ram intake too, and my cars stalls also at times, same thing when coming to a stop or pulling into a parking spot at low speed and low rpm. Has anyone fixed this problem, I am told that it is the maf getting turbulence or something and it getting confused. Also after the car stalls its a hard start, take s afew for it to start back up. Any suggestions would be appreciated. All conections and all are tight, so I dont know what else it is.
Thanks
Old May 19, 2004 | 11:49 PM
cokofellah's Avatar
put back the stock intake, and let the stock ecu run the show.......if it (stalling, etc.) doesn't come back, then...
hate to do it, but I will.......
At worst, I'll have to figure out how to set-up a stand-alone "brain"...if i decide on continuing my car's "aftermarket life"
*anyone know how to tune using a MOTEC?
mikebuff35
Oct 3, 2016 04:18 AM
MLucas13
Oct 23, 2015 06:31 PM
joedr
Aug 22, 2008 01:11 PM
RSGuy
AEM EMS
17
Jun 6, 2007 08:28 AM
PPI
AEM EMS
Apr 21, 2006 09:02 AM
