View Poll Results: Is the MR worth the extra money over the GSR?
Yup, ACD and 6-speed is a must!
501
44.93%
Nope, not worth the money.
614
55.07%
Voters: 1115. You may not vote on this poll
MR vs EVO: Is the MR edition worth it?
Old Nov 28, 2004 | 05:58 PM
  #151
Jhodel's Avatar
I did see the gauge pack and thought that would be a good adder - maybe I'll add that to our car - not sure about the aluminum roof. I assume the curb weight would be less with the aluminum.
The dealer had two 04s which I was thinking about, but I decided to get the 05 to kind of 'split the difference' with an MR and at least get the extra HP/torque and limited slip front differential and ACD.
We put 150 miles on the car today and had a great time.
Jim
Old Nov 28, 2004 | 06:06 PM
  #152
erikgj's Avatar
Originally Posted by Jonasan50
Nope.. I'll be putting in a front LSD relatively soon... That's all I need... Keep that damn ACD.. When that schit breaks, better get a bank loan to fix it... You think Mits is gonna warrantee that? ACD is just another part to turn and break... I'm not a big highway driver so I don't really need the 6 speed... With the power I have for the moment, the 5 gears are quick enough, damn...
The ACD system does not have the reliablity problems that the early AYC systems had. The six speed does not change the top ration by much at all.
Old Nov 29, 2004 | 10:33 AM
  #153
tahoeacr's Avatar
Just read all these pages. I agree with MARON. Good to see objective track times.
Lowering your evo is not the same as the lower cg of the MR. The mr has a lower cg but keeps the roll centers the same. The cg being closer to the roll centers applies less torque on the suspension when cornering. This is good for spring rates and sway bars. Lowering your evo(by shorter springs) lowers the cg but moves the roll centers farther away from the cg requiring stiffer springs and sway bars. Of course this is something that you would have to drive good enough to set the TTD to notice.
Old Nov 29, 2004 | 10:44 AM
  #154
EidolaDream's Avatar
Originally Posted by juancevo8
with less than 5k you can upgrade the 03 like I did and I can beat any MR on the track... come on !! it is only 6 more hp compare to the 03
only six clamed but over 20 dyno proven.. but yes I see your point, its really up to the drivers.
Old Nov 29, 2004 | 10:58 AM
  #155
Rez90's Avatar
ok...so my 03 has been destroyed. (not going to tell you how or why...don't even ask.)
but i am in the market for a new EVO. GSR or MR.....i am having such a hard time with this decision
Old Dec 2, 2004 | 01:50 PM
  #156
GOKOU's Avatar
Sorry about the bad news. Does this mean you're saling your stuff for a reasonable price?
Old Dec 2, 2004 | 02:13 PM
  #157
Thedread's Avatar
I've driven both and the MR isa more satisfying car to drive. If cost is not an issue, then by all means the MR. Otherwise you can't go wrong with the GSR.
Old Dec 2, 2004 | 03:37 PM
  #158
Maron's Avatar
Originally Posted by Joe250
GSR:
4661/5050/5129/4888
MR:
4677/5163/5369/5523/5588
I see a nice improvement in 4th and 5th, so the 6speed looks better gearing-wise for the track. For autox work, I would think you are worse off with the MR's trannie, additional weight, and weight distribution. Some of that is offset by the roof, wheels, and suspension.
Again, each Evo this year has its pros and cons. Look over all the data and make an informed decision.
Joe
www.joe250.com
I don't agree with your autox comment. Having autocrossing both the GSR and the MR, I find the MR to stay spool and the power available quicker out of tight turns which to me is a lot more beneficial.
Old Dec 2, 2004 | 04:16 PM
  #159
hi_nrg_fizzix's Avatar
FYI,
All 05's make the same HP/TQ at the flywheel. So claims that the MR has more HP/TQ at the flywheel and are unfounded, and technically impossible. There is car to car variation which will be seen on the dyno, but MR's do not have special "pixy dust" which gives them more at the flywheel than any other '05. What you see at the wheel on a dyno may be different due to the 6 speed's gearing.
Old Dec 2, 2004 | 06:58 PM
  #160
05-EVO-GSR's Avatar
Originally Posted by hi_nrg_fizzix
FYI,
Agreed. Even then, as long as the ratio is as close to one to one as possible, the power should be the same. The pixy dust is the extra $5000 being spent to sweeting the lemon.
Old Jan 19, 2005 | 06:54 PM
  #161
05-EVO-GSR's Avatar
Which model did you end up with?
Old Jan 19, 2005 | 07:54 PM
  #162
TurboWill's Avatar
Yes my next Evo would be a graphite grey MR. Although I plan on being in a GT2 soon, so I will keep my Evo for daily driver.
Old Jan 19, 2005 | 07:59 PM
  #163
escoson's Avatar
when i purchased my evo in december i went with a '05 gsr instead of MR for the reasons that im going to be modding the suspension and i have no use really for a 6spd since im not going to be tracking the car.
Old Jan 19, 2005 | 08:03 PM
  #164
housedj's Avatar
Thumbs down
i could have gotten an MR instead of the new eblue 05 gsr but why? don't need the fancy roof, wheels (yuck), & 6 speed (if you shift right you're always in the powerband). i was unable to justify the price hike not to mention i refuse to pay over $700/month for a 4 cyl car no matter what it is!!!!
Old Jan 24, 2005 | 10:20 PM
  #165
Turbo-Ron's Avatar
NIce comments Maron.
You were comparing an 03 Gsr to the MR. if I'm not mistaken.
The 03 was lacking LSD and some performance improvements that the 05 GSR will share with the MR.
I prefer a 5 speed for autocross because it will tend to hold 2nd gear just a little longer and maybe avoid having to shift up and back in some places.
Is'nt it likely that the 05 GSR is alot closer to the MR than the 03 GSR?
Plus 5 seconds diference?! - might your driving skills be a big factor as well here?!
