All Part Number Request Go Here
Old Aug 2, 2014 | 07:12 AM
  #4111
hac0504's Avatar
I'm looking for two part numbers. One will be the tranny brass plug (top of tranny, to remove TOB) and the other will be the tranny access hole cover(bottom of tranny)
Old Aug 9, 2014 | 10:02 PM
  #4112
kerambit's Avatar
Positive battery terminal
Hi, I need the part number for the positive battery terminal that's connected to the fusible link. Thanks.
Old Aug 9, 2014 | 10:15 PM
  #4113
kerambit's Avatar
Nvm, I found it already, just in case someone need it, it's MU800888. Cheers
Old Aug 11, 2014 | 04:36 AM
  #4114
pls1968's Avatar
Originally Posted by XSilverJ
MB569372
but I'd get a Dimple one
http://www.drainplugmagnets.com/mitsubishi.php
I have this for the oil pan. Will look into it for Tranny. I assume the Tranny, Rear diff and Transfer Case all use the same magnetic oil drain plug correct?
Old Aug 13, 2014 | 03:55 PM
  #4115
doncarbone's Avatar
broke this plug off a cam position sensor...
EDIT: found them
intake sensor (mivec):
MR507814
exhaust sensor / non-mivec:
MD327107
Old Aug 22, 2014 | 12:12 PM
  #4116
eking's Avatar
Ignition Switch
Ignition switch has gone bad on my 03 EVO. Can anyone verify the part number?
Is this the correct one, Part Number: MN113754?
Old Aug 23, 2014 | 11:47 AM
  #4117
Peazoo's Avatar
Evo 8 or evo 9 Passenger side under tray part help
I am trying to find the missing part which connects to the fender liner, lower lip, and main under tray.
Please see the picture from underneath the passenger side.
There is a missing plastic piece.
Old Aug 24, 2014 | 12:06 PM
  #4118
eking's Avatar
Just in case anyone was wondering, this is the correct number. Called local Mitsubishi dealer and it is $128.00 plus tax, so i called Autozone. They had it in stock for $53.00, different part number, LS1294. Five minute install, works perfectly.
Old Sep 1, 2014 | 04:18 AM
  #4119
Peazoo's Avatar
[QUOTE=Peazoo;11286011]I am trying to find the missing part which connects to the fender liner, lower lip, and main under tray.
Can someone take a close up pic of underneath the passenger side fender well to tell me if this is normal? Is there supposed to be a gap?
Old Sep 1, 2014 | 05:30 PM
  #4120
tsidrift1's Avatar
Looking for the part number of an oem driver side front halfshaft.
Thanks
Old Sep 1, 2014 | 08:55 PM
  #4121
XSilverJ's Avatar
Thanks
You talking about this piece?
MR953315
http://www.streettunedmotorsports.co...inner_axle.htm
Old Sep 3, 2014 | 03:28 PM
  #4122
nk1124's Avatar
anyone know what the part number for the white plastic clip that holds the hood prop down is?
Old Sep 5, 2014 | 07:02 AM
  #4123
badev0's Avatar
I need the part number for this lower cubby. This cubby is included in radio relocation kits and it is also the OEM part for EVO MR's for the gauges.
Old Sep 7, 2014 | 09:31 AM
  #4124
LV///R's Avatar
Could someone please give me the part number for a 2006 evo front eccentric bolt and nut? Thanks in advance.
Old Sep 10, 2014 | 06:24 PM
  #4125
eazlan's Avatar
6 Speed MR Console
Hi Mate,
I couldn't find the part number for 6 speed console evo 9 mr, the
one int the list is MR647677 Console panel around Shifter (grey) which is 5 speed.
Can you help me on this ?
I need the console, knob, lever, shifter box, leather lever cover part number..
