All Part Number Request Go Here
Old Apr 2, 2006 | 08:59 PM
  #1006
Andrew LB's Avatar
I've searched but cannot find the part number for the 2006 Evo's Ashtray. The bottom portion in particular if its in separate parts. My ashtray door is fine and i have the spring. I just need the bottom tray portion.
Thanks!
Old Apr 3, 2006 | 08:17 AM
  #1007
mdosu's Avatar
Originally Posted by mdosu
I need the PN's for gauge cluster light bulbs...all 4... here's a picture: http://bolsen.homeip.net/evolights.htm
I believe 3 of the bulbs are the same, and the other is smaller than the 3.
I have an 03 evo if there's a difference.
thanks.
Old Apr 4, 2006 | 07:45 PM
  #1008
k270kmh's Avatar
I received some exhaust parts and I need to confirm if they are Evo parts:
MR529714
MR571083
MF241309
MR281085
Thanks
Old Apr 5, 2006 | 09:44 AM
  #1009
Russell K's Avatar
Originally Posted by Russell K
Does anyone know the part # for the Airbox's rubber grommets? There are two I believe. The bolts pass through these, holding down the air box. I broke them reinstalling the airbox.
Can someone help me out here?
Old Apr 5, 2006 | 10:44 AM
  #1010
SoR's Avatar
SoR
seems like this thread is dead
Old Apr 5, 2006 | 06:25 PM
  #1011
SoR's Avatar
SoR
Originally Posted by SoR
Need new oil cooler bypass valve. Mine is leaking oil badly
#9 in the picture. PN please
In case someone else needs this - PN (at least for 03 Evo) is MD356695
Old Apr 6, 2006 | 04:40 AM
  #1012
WarmPepsi's Avatar
Originally Posted by WarmPepsi
looking for the stock belt clip and bolt for both driver and passenger sides.
(the clicker on the inside, and the bolt that goes into the frame to hold the clicker in, probably is sold as a package)
thanks.
bummp.
Old Apr 9, 2006 | 03:24 AM
  #1013
Trueno86's Avatar
Does anyone know the part #'s for the
Turbo Water Feed rubber hose
Turbo Water Return line rubber hose
Thanks,
Adrian
Old Apr 9, 2006 | 06:11 PM
  #1014
SuperHatch's Avatar
Thanks,
Adrian
Feed: MD363256
Return: MD082347
Old Apr 9, 2006 | 06:14 PM
  #1015
SuperHatch's Avatar
bummp.
Do you mean the button part that releases the belt? If so....
MR979752HB - Left
MR986188HA - Right
I can't seem to find the bolts though, they might be included in that part
Old Apr 9, 2006 | 06:15 PM
  #1016
SuperHatch's Avatar
Can someone help me out here? (Airbox rubber grommets)
MR450097
Old Apr 9, 2006 | 06:21 PM
  #1017
SuperHatch's Avatar
thanks
MR444536 - turn signal lamps and warning lamps
MN134600 - LCD
MN134599 - speedo/tach
Old Apr 9, 2006 | 06:23 PM
  #1018
SuperHatch's Avatar
Originally Posted by justchil
I need the part# for the wheel well plastic on the passenger side.
I found this but it's for the driver side:
2003 lancer evo 8 inner fender wheel well plastic driver side front
MR954175 - Shield Kit, Splash, Front LH
MR954176
Old Apr 9, 2006 | 06:34 PM
  #1019
SuperHatch's Avatar
Originally Posted by [TYPE]SS
Original trunk "lancer evolution" badge part # plz~
thank you
MN154914 lancer
MN154916 evolution
Old Apr 9, 2006 | 06:37 PM
  #1020
SuperHatch's Avatar
Originally Posted by evo7racer
Anyone know part # for stock right A-pillar?
MR631943
