A/C makes car almost stall sometimes
i updated my ecuflash to the latest release and it included some new tables for idle conditons. i set most of the idle tables to 1000rpm. the car idles perfect with AC on and off but problem still exists when stopping with ac on...still does not catch the idle. if you press on the gas while pushing in the clutch and let the rpm drop slower then it will idle fine, just the sudden drop in rpm causes the problem.
c
c
c
c
I do not have the "High intake air temp ISCV" in m evo9 rom.
c
c
So you never had the car shut off on you around a corner? That to me is a problem, so why not fix it? There's plenty of modified cars out there that don't have this issue, so why should we?
