How much did you pay to save weight?
Old Feb 13, 2007 | 09:05 AM
  #46
IXToes's Avatar
Man I wish I can get my evo to weigh 3k or under. This car is heavy! It costs so much money to do it right
Old Feb 13, 2007 | 09:17 AM
  #47
Q8_EVO's Avatar
"Will my AMS-style eBay intercooler work just as good as the real deal, yo?"
LMAOOO
Old Feb 13, 2007 | 09:26 AM
  #48
9sec9's Avatar
I am going to remove any unverified data, until it is verified. It's not a matter of questioning someone's post, but rather making sure that the information is correct. Afterall, some readers will be using this info to make decisions on the next mods for their cars. Hope everyone understands.
Old Feb 13, 2007 | 12:57 PM
  #49
tursup's Avatar
Thanks for the weight info. Very cool.
Old Feb 13, 2007 | 01:15 PM
  #50
sonicnofadz's Avatar
Originally Posted by evobeatsti
volk ce28n 17x8.5 14.5 lbs vs stock enkeis at 21 lbs 26 lbs for $2000 dollars.
buschur mini battery $250 for 20 lbs
Jdm rear bumper with rear crash bar delete id say 30 lbs for 700 dollars
remove all the stuff in the trunk 50 lbs
remove floor mats 4 lbs
rempove back seats 10 lbs for the bench 15 more for the back.
remove rear seat belts 2 lbs.
remove stock intake box and braket and replace with bushcur unit 6 lbs $250
CF trunk (soon to come) 7lbs vs stock w/ wing which is 27 lbs $700 for 20 lbs
CF hood (soon to come) 11 lbs vs stock 20 lbs 9 lbs for $800
remove grill thingy in the stock hood about 3 lbs, spark plug cover .5 lbs, antenna .5 lbs.
ams exhaust 33 lbs vs stock at over 60 lbs. $900 for 27 lbs
hollow rear sway bar $200 for 3 lbs.
thats all that i have done that helps for whenever i go to autox the car
So how much does your car weigh now?
Old Feb 13, 2007 | 01:19 PM
  #51
9sec9's Avatar
Before or after a burrito lunch? I'm waiting on more parts to come in. Still sitting at 2713 lbs. Next diet as soon as the 'race' set of wheels and tires come in.
All of these parts and changes are NOT necessarily mine. I'm posting everyones changes, to create a list for those interested in the same changes.
Old Feb 13, 2007 | 01:24 PM
  #52
At 2713 lbs, your car must be ridiculous on the track. Hope you enjoy it!
Old Feb 13, 2007 | 01:49 PM
  #53
KevinD's Avatar
i got around to removing my intercooler sprayer and weighed it.
with 1/2-3/4 full of water, it weighed 8.xx pounds. the accuracy of the weigh was based off a digital bathroom scale that wouldn't register the tank by itself. therefor i had to weigh myself, then weigh myself holding the tank to get the weight of the tank. because this process is stupid, and the accuracy of the bathroom scale is questionable at best, i went ahead and ordered myself a digital 50lb max postage scale off ebay for 25 dollars shipped it is sopposedly accurate to .1oz which is more then enough for the stuff we are looking at. once i get it i will tear my car apart to get some weights some weekend.
Old Feb 13, 2007 | 01:53 PM
  #54
dudical26's Avatar
KevinD, any idea what your JIC's weigh?
Old Feb 13, 2007 | 02:06 PM
  #55
KevinD's Avatar
i've installed, my JIC's, ohlins, teins, KW's, and just springs on other evos, and quite honestly the coilovers save very little to no weight over the stock struts(teins being by far the lightest, but also the cheapest, and worst performing). i wouldn't be surprised if it is less then 10 pounds total for all 4 shocks.
the JIC;s are not on my car right now as i have them off to be rebuilt. i'll throw them on the scale when i get it, and i'll throw some stock struts on the scale as well.
Old Feb 13, 2007 | 03:00 PM
  #56
dudical26's Avatar
According to Buschur
http://www.buschurracing.com/weight-reduction.htm
Stock is 64.6
I have heard JIC's weigh under 50. That is considerable.
Old Feb 13, 2007 | 03:14 PM
  #57
KevinD's Avatar
15 pounds for 1700 dollars is over 100 dollars/lb thats the highest yet. but i'll weight them anyway. i think they are more then 50 though.
Old Feb 13, 2007 | 03:18 PM
  #58
Sharkbite2000's Avatar
Thats alot of weight off , I'm stock so i must weigh 3300 and change
Old Feb 13, 2007 | 03:36 PM
  #59
DJ Brett B's Avatar
Originally Posted by Lancerlover
The rotating weight savings are very important. Then comes weight savings at the highest point of center of gravity which means the roof. These are 2 focus areas in the MR and SE that Mitsubishi engineers decided were most important. What's the weight difference between an MR and GSR? Minimal right? But the performance numbers (Slalems/Around turns) are due to the areas of weight savings themselves.
One of the reasons I decided to go with the MR is the aluminum roof panel which only comes on the RS and MR models (dont know about evo VIII I am speaking specifically about the IX)... cant get that on the GSR because some of them have the SSL package!
FYI you can find mini batteries out there for around $100 if you actually do some research before forking out $150-250 from some of the vendors out there
20 lbs for $100= $5/LB
Old Feb 13, 2007 | 04:46 PM
  #60
GreddyEvo's Avatar
Nobody has a carbon fiber prop shaft to add to the mix! That is rotational savings you would be able to feel.
