Boost creeping...a lot
Old Jan 26, 2007 | 01:16 PM
  #46
UpstateEVOVIII's Avatar
running out of ideas...have the soft spring in the forge unos and everything...
Old Jan 26, 2007 | 02:13 PM
  #47
cityhugo's Avatar
is ur o2 housing
Old Jan 26, 2007 | 02:43 PM
  #48
Next 2 projects:
Forge Wastegate
Swap back o2 housing if the wastegate isn't the issue....
...until Monday
Old Jan 26, 2007 | 09:09 PM
  #49
sparky's Avatar
I just PM'ed you a how-to on setting your WG's preload. I notice you plan on doing the Forge WGA. So, in that case, you should wait and set the preload once you've installed the Forge. Which BTW is a really good WGA unit.
Old Jan 27, 2007 | 06:28 AM
  #50
First of all, thank you for everyone who posted in this thread and pm'd me in order to help with the creep problem. After going through every issue and making every adjustment possible it appears it came down to a hose attachment which wasn't sealing properly. All new reinforced hoses (which I had mentioned) were installed and then re-clamped with new clamps. Car is finally hitting and holding 20psi with the mbc turned all the way up. Now once I'm done in the office today I'll set the mbc to 23-24psi with my tune and life will be skippy.
THANK YOU ALL!
Old Jan 27, 2007 | 01:24 PM
  #51
kapolani's Avatar
Sweet.
Glad you found the problem.
Old Feb 1, 2007 | 07:17 AM
  #52
after thinking the problem was solved, it magically reappeared a few days later. thinking it was the stock wga we replaced it with the forge unit which seemed to solve the problem...a day later the problem is back. i read somewhere something about the arm possibly hitting a heatshield so that's next on the list to check. lastly will be taking the turbo out adn putting the stock o2 housing back on to see if that resolves this blasted issue. kill me please
this is making me want an sti:P
Old Mar 4, 2007 | 10:11 AM
  #53
justastockevo's Avatar
well, same problem here. i've done some research, it leads me to conclusion this is our o2 housing. the wastegate passage there is smaller compared to stock, thats why there's creep.
does it appear in cold weather and when there's low backpressure (a full TBE)??
Old Mar 4, 2007 | 10:41 AM
  #54
TTP Engineering's Avatar
wrong
Old Mar 5, 2007 | 11:28 AM
  #55
Sully 18's Avatar
didnt feel like reading the entire thread but i had the problem and i change my mbc and it went away
Old Mar 5, 2007 | 11:38 AM
  #56
Ding Ding Ding.
Old Mar 5, 2007 | 11:43 AM
  #57
TurboIX's Avatar
Get a EBC IMO..
Old Mar 5, 2007 | 05:19 PM
  #58
bluebyu36's Avatar
i changed my boost controler to that wasnt the problem my wga was broke
Old Apr 13, 2007 | 04:32 PM
  #59
indeed. i didn't change my EBC, but i adjusted WGA and the problem is gone, hitting solid 21 psi on every gear. woohoo, no boost creep
thanks everyone.
Old Apr 13, 2007 | 10:24 PM
  #60
Sully 18's Avatar
i spike at 21 then it falls down to 17 when i keep getting faster
latreille
Nov 27, 2012 11:42 AM
badev0
14
Jan 30, 2010 08:29 PM
gsr0801
Nov 25, 2008 01:24 PM
v8<turbo4
10
May 6, 2008 09:20 PM
riksride
May 4, 2007 01:16 PM
