EGR DELETE help needed please
Old Jul 20, 2007 | 02:28 PM
  #31
EvoDan2004's Avatar
Originally Posted by dudical26
Do you have a link showing how to do this?
where it is i dont know. your best bet is too search the jdm map sensor threads... its in there somewhere...
Old Jul 20, 2007 | 02:30 PM
  #32
EvoDan2004's Avatar
Originally Posted by sonicnofadz
I agree EGR's will increase gas mileage, I have noticed that and totally agree. I also completely agree that on the Evo, the valve is shut during WOT, so its only really open at part throttle conditions. However EGR's do indeed have one negative side effect. Overtime, they dirty your intake manifold, and rob power by restricting the overall flow going through the manifold (they coat the walls of the manifold with black soot, which creates a lot of turbulence to the airflow). Ever check out a race car engine? You won't find ever find an EGR valve on one. People remove the EGR valves for the same reasons that people put on catch cans, to prevent gunk from clogging the intake tract..
finaly someone understanding my opinion to remove the egr... thank you...
Old Jul 20, 2007 | 02:34 PM
  #33
EvoDan2004's Avatar
Evodan, don't you know kreionic (charles)? I think he told me about your problems with your car (shop put in revolvers and couldn't get the car started again). Hope your car is doing better now!
yes i do. he's a good man.
i had a guy install cams and it was just a mess... i then went to a shop who in turn fixed the car. from start to finish it was a $1500 cam install.... and no car for 2 weeks.....
it is running great right now... thanks for asking....
Old Jul 20, 2007 | 02:35 PM
  #34
EvoDan2004's Avatar
so back to the topic here.. anyone know how to delete the egr the right way????????
Old Jul 20, 2007 | 02:37 PM
  #35
EvoDan2004's Avatar
just connect the two together. It can be done by removing one of the vac lines off the point where they connect to the throttle body and just connecting one line to both nipples on the TB.
mind giving a little more detail???
Old Jul 22, 2007 | 10:45 AM
  #36
EvoDan2004's Avatar
bump
Old Jul 23, 2007 | 05:51 AM
  #37
MR Turco's Avatar
I have some knowledge of EGRs from Nissan motors. With the adaption of VVT, as previously stated, the need for EGRs becomes moot as you can replicate the effect of EGR by varying the cam timing. From what I understand the IX motor with the MIVEC has EGR, is this correct and if so why?
Also EGRs do not usually effect power in anyway, the problem is usually it is connected to the exhaust manifold and can make it hard to get a new one or switch to a turbo manifold, again from nissan experience. But at no time has anyone on a Nissan motor experienced gains or losses from removing egr. It really does almost nothing except clutter the engine bay.
Old Jul 23, 2007 | 05:56 AM
  #38
MalibuJack's Avatar
Most aftermarket manifolds just block it off, on the stock manifold its just more effort than its worth to remove it, and pointless to remove it since it offers no performance loss/gain. Like mentioned earlier, it is supposed to reduce NOx emissions at part throttle, and helps improve fuel mileage.
FWIW Cams wreak havoc with NOx emissions also.
Although I'm not a tree hugger, I do think its unwise to remove it for legal reasons, in some states they do check for its existance during an inspection, others don't as long as you don't throw a CEL.
The short simple answer is don't bother removing it just to remove it. But I wouldn't lose sleep over it if you put in an aftermarket intake manifold. as long as you can resolve the CEL light issues.
Old Jul 23, 2007 | 06:01 AM
  #39
MR Turco's Avatar
I agree, I am also not a hippy *****, but if it doesn't hurt you, and helps the environment, why not keep it on?
SilentCool
Lancer Troubleshooting
31
Mar 13, 2018 05:07 PM
thedru13
Aug 31, 2012 05:55 AM
wadeholmes
May 15, 2012 07:00 PM
neonglh
16
Feb 4, 2009 09:36 AM
Spinsall4
Nov 27, 2007 09:50 AM
