Starting to get upset with the evo..
Old Sep 20, 2007 | 11:20 AM
  #46
Pure Playaer's Avatar
Originally Posted by theblue
I keep seeing people say that cams will help spool a turbo???? I don't see how a cam helps spool... all a cam does is shift where the power is made. I would expect him to have more peak power, but if anything worse spool.
thats exactly what i thought also
Old Sep 20, 2007 | 11:27 AM
  #47
JordanS4's Avatar
Originally Posted by Pure Playaer
Everyone suggests to upgrade cams, but to be completly honest untill i see some amazingggg results from cams for evo9s i dont plan on getting any..
Most people upgrading cams on Evo IX's are still on stock turbo or did not do a baseline vs. cams.
On the exact same mods and boost (and day, within an hour and a half) between the Stock IX cams and DTM 280's I made 20 more WHP on the stock turbo. Is that not good enough? Your creating a huge restriction in the head by not letting enough of that air get in the motor. Not only that, but your tuner gave you "no timing". Timing has a significant effect on spoolup. You can delay or advance spool a great deal through tuning and properly running the turbo (i.e. in its efficiency range) with good fuel and free flowing passages to get the air into the motor. Like most people said a
Proper Tune
Cams/Porting the Head
Alcohol or Race Gas to allow more timing during spool with less chance of knock/detonation
More Boost
You should have a 500 whp (dynojet) car. With a built motor you could go much higher. On a built 2.0 and pump/alky with a 50 trim/35R hybrid I've seen almost 500 whp on a Mustang Dyno.
Old Sep 20, 2007 | 11:28 AM
  #48
JordanS4's Avatar
More air in the engine = more gas expelled = more air hitting the turbine = FASTER SPOOL!
Old Sep 20, 2007 | 11:35 AM
  #49
tvbf1's Avatar
Nice explanation, or you can purchase the new HKS V-Cam system. I saw it on the Option magazine. Looks pretty impressive. But I don't think they have it in the US yet.
Old Sep 20, 2007 | 11:52 AM
  #50
theblue's Avatar
how is a higher duration cam helping to get more air into the motor? all you said was that the turbo will spool sooner which is what I'm arguing in the first place. can you show that cams increased spool by means of more area under the curve down low instead of just more peak power?
sure timing might help spool, but how is changing to a higher duration cam going to allow you to increase timing?
Old Sep 20, 2007 | 11:57 AM
  #51
JordanS4's Avatar
the point is with a 35R and stock everything (as far as getting air into the motor sooner goes) it becomes a huge restriction and that is one of the factors of his slower spoolup.
Old Sep 20, 2007 | 12:01 PM
  #52
Durbo20vT's Avatar
check your connections from the turbo to manifold and the manifold to cyl head. make sure bolts are torqued down and the gaskets are not shot. reassure these are all sealed before getting a re-tune.
if those check out, its DEFINITELY your ****ty tune causing the late spool. timing has a lot to do with spool up. if your timing is ****ty, your car wont spool as quick as intended. without logs though, nobody on here can directly diagnose your problem.
Old Sep 20, 2007 | 12:03 PM
  #53
theblue's Avatar
that still doesn't explain to me why a cam upgrade would allow for better spool.
I only push this question because one of the reasons I didn't cam my car was to allow me to putt around town at low RPMs. if you can prove that I won't lose any spool or that I'll gain then I'm going to cam my car soon.
Old Sep 20, 2007 | 12:05 PM
  #54
kinloch99's Avatar
the answer is simple, stock motor+stock cams = Laggy 35r , alot of the 35r u see are running on built 2.3, and jun cams. people some times forget that turbos run on exhaust, the evo already comes with a large turbo, now u throw on a huge turbo, what do u expect, u need more exhaust.
Old Sep 20, 2007 | 12:07 PM
  #55
kinloch99's Avatar
TheBlue, put cams in your car then u will understand, yes cams feed MORE fuel and air into the engine and allow MORE exhaust to leave, u are 1000% wrong thinking that they dont
Old Sep 20, 2007 | 12:09 PM
  #56
theblue's Avatar
cams require more fuel and thus air, but that requirement doesn't help the turbo spool.
somebody must be able to explain this better?
I agree exhaust help increase spool like an intake does (both free up restriction) but cams won't help spool since they don't reduce restriction in any way??
things that help spool:
- exhaust
- intake
- timing
- electronic boost controller (can flutter wastegate?)
- I/C (smaller pressure drop)
- charge pipes that don't flex or reduce length
what else?
Old Sep 20, 2007 | 12:11 PM
  #57
kinloch99's Avatar
more fuel + more air = more exhaust. more exhaust = faster hotside. faster hotside= faster turbo.
  #58
NYEvoguy's Avatar
if your that unhappy with your set up....I will gladly take the 35r off your hands and give you my stocker in it's place :-)
Get some cams and Meth/Alky and a good tune and you should be surprised at your gains. You can also stroke your motor out which will help out greatly.
Old Sep 20, 2007 | 12:14 PM
  #59
JordanS4's Avatar
pure playaer are you starting to understand what I'm saying
Old Sep 20, 2007 | 12:17 PM
  #60
theblue's Avatar
I'm not disputing that.
how are the cams responsible for more air at low RPMs when the whole point of the upgrade is to shift power up the curve?
