need help on fluid changes
Old Dec 26, 2007 | 07:38 PM
fenriq007's Avatar
So i'm getting my oil changed tomorrow and i need my trans and tranfer cs oil changed too. problem is dealer charges an arm and a leg. My cousin works in a garage so he said he would let me use it and have the owner help me out to do the changes. I need to know what fluids to purchase from the dealer to do the change. i know diaqueen for the transmission but for the rest??? Also i read some of the post on how to do them but where can i get a copy of the service manual or does anyone have one. Thanks guys.
oh i would search a bit more but I'm at work right now and really can't.
Old Dec 26, 2007 | 07:51 PM
BBS's Avatar
BBS
Dude, please read your manual before you make a thread. The manual states which fluids to use (or its equivalent) and how much of each you need. Service manuals are avaiable in book form or on cds. Both are readily available on ebay or amazon.com
Old Dec 26, 2007 | 08:09 PM
max2evoix's Avatar
redline
Old Dec 26, 2007 | 08:14 PM
Wicked E's Avatar
umm... Diaqueen for rear and T/C
MT-90 for tranny...
I did my homework in .3 seconds the other night... It took you longer to make this thread than it would have to searched as evidence by the time stated above...
Old Dec 26, 2007 | 08:23 PM
VtexGt3's Avatar
the only problem you can posibly run into is that the oils are a little too viscous and its hard to get them to go into the fill plug holes without spilling out everywhre because of the air inside after you drained it. But otherthan that, do it yourslef and save $500, and some peace of mind too
Old Dec 26, 2007 | 09:19 PM
dog_dealer's Avatar
Transmission fluid
Diaqueen Super Multi-Gear Oil 75W-85 (Part # - MZ313376)
Transfer Case and Rear Differential fluid
Diaqueen LSD Gear Oil (Part # - MZ3775610)
can't go wrong!
Old Dec 27, 2007 | 03:53 PM
6-speed's Avatar
Not too hard to change the transmission and transfer case fluid.
Here's the famous evomoto link on how to do it:
http://evomoto.com/index_tech.php?tP...a2d72b547c965e
Here are some tips:
1. Get a plastic bottle that holds more than the required quantity of fluid and mark it at the max fill quantity.
2. Pour the transfer case or trans. fluid into this container up to the max fill amount stated above so you don't overfill.
3. Use a vinyl hose to fill; this makes the job sooooooo much easier.
4. Always invest in a good set of funnels
5. Do not fill too fast; the liquid is thick and takes time to flow
BTW, the job is much easier without the stock airbox and undertray.
The rear diff is a bit harder since you cannot use gravity to full the rear diff.
You can get a transfer pump or a nice turkey baster Serious.
Old Dec 27, 2007 | 04:01 PM
RussellM's Avatar
Plat Vendor
I keep both in stock, but if you are in a hurry Id suggest the dealer...Im sure they will be more than me though. Here is a link. Im doing free ground shipping on Diaqueen Fluids.
http://www.mitsubishiparts.net/cart/...313376+3775610
Old Dec 27, 2007 | 04:16 PM
EvoJoeIX's Avatar
all you would need to do is go to the dealer and ask them for the fluids...
St1g
Aug 7, 2015 02:24 PM
akgirl
Lancer Tranny/Drivetrain Tech
Oct 15, 2014 07:50 AM
c.scatena
Sep 28, 2012 08:18 PM
Exsubie22
May 24, 2011 08:13 PM
