Modification Regrets?
Old Sep 17, 2021 | 01:06 PM
  #1141
WalkerWakaWaka's Avatar
5 Year Member
My only regrets are...
1. Waiting so long to start modifying my Evo 8....although it helps at 43 years old to have the income to put in good parts and do it right.
2. Trusting a Mitsu dealership to change my timing belt. Should have just researched and done it myself. They had the balancer off and vibrated the crap out of my engine.
Old Sep 17, 2021 | 02:06 PM
  #1142
kaj's Avatar
kaj
Originally Posted by Jaraxle
Trying a 100 cell "performance" cat to try and clean things up a bit.....it didn't. Still smelled like @ss....Kids would choke on fumes at streetlights. Penguins died in Alaska or wherever they hang these days.
Then trying a 200 cell cat..... same result, just now I felt more dumb. Made a mistake TWICE and the catalytic converters sit on a shelf...
Finally spent the coin for a GESI G-Sport CAT and all the smells went away and power loss was negligible. It is rated at 850hp and EPA certified as well, which is probably why it actually cleans.
Exhaust leak? I have no cat but don't smell anything.
Originally Posted by WalkerWakaWaka
I have to second kaj comment...my modified Evo is so much happier than stock. I'm a big fan of being careful and trusting a good tuner for advise and a safe setup.
Agreed. Granted I'm only at 450whp so my car is stock-ish. So much better than stock, with probably
​​the same reliability.
This may sound weird....but timing belt changes are actually one of the things I LIKE doing. It's straight forward if you have the right tools. Plus it's nice to know you have all fresh stuff on there that'll last a while.
Old Sep 17, 2021 | 04:26 PM
  #1143
Jaraxle's Avatar
Depends how much time you sit in traffic, which way the wind is blowing, and whether your interior vents are set to suck outside air. There was no exhaust leak, it was coming from the tailpipe and ending up in the cabin. I have a baby car seat in the back, she is now 3 years old but I didn't want an infant breathing at s***. Tell me you haven't been behind someone before with no cats and choked on those fumes?! Oh and if you run E85 it is almost impossible to detect.. so maybe that is why you never noticed ?
Old Sep 17, 2021 | 05:07 PM
  #1144
RazorLab's Avatar
You can smell it more on the 10’s because they have an outlet on the drivers side as well. On e85 you can barely tell.
I’ve run catless as long as I have owned evos, 16+ years, I now have the same GESI cat on my Evo 10 and can’t smell anything now.
Old Sep 17, 2021 | 05:33 PM
  #1145
Jaraxle's Avatar
Exactly. Thanks for backing me up. So someone going through these regrets may believe us that the 100 cell or 200 cell "performance" cats actually do NOTHING (as far as my nose can tell) which is why they are not EPA certified.
The GESI G-Sport is the only cat in my research and experience that is performance oriented and actually works. I found them by searching how the turbo LAMBO kits are built, and from there found out how good they were.
Old Sep 17, 2021 | 09:15 PM
  #1146
kaj's Avatar
kaj
Ah. You have a X. That's a whole 'nuther animal. I have the old one
Old Sep 18, 2021 | 08:30 AM
  #1147
Spooled_IX's Avatar
What modifications do you regret not doing sooner? Engine? Suspension?
Old Sep 21, 2021 | 10:35 AM
  #1148
ViciousLSD's Avatar
Been running the PC680 for 10years +
Trickle charger is a must
I disconnect the batt every time. Sometime even on overnight hotel stays
Old Sep 21, 2021 | 10:54 AM
  #1149
ViciousLSD's Avatar
My biggest regret is the WhiteLine front swaybar + wavetrac installed at the same time. I didnt have the courage to remove them so I have been fighting them autoxing for several years, several tires and springs combos ago. My wavetrac is not apparent/aggresive anymore, and I finally did the DIY swaybar swap back to stock and adding an even 'softer setting' hole
2nd biggest regret was polishing (polishing compound) my own car. I just put burn marks/paint damage and also ended up scuffing up all the rubber on the roof and glass.
I have been going with cheaper options when it comes to parts and upgrades (not on tuner services) and so far theyre all fine (except for that fake ngk sparkplugs. fine for autox but melted/cracked on track)
Old Sep 21, 2021 | 03:51 PM
  #1150
After 2 back to back failures w/the PC680 I gave up on them. Been running the CSB HRL1280W (less expensive & has performed even better)
Layed out my experience here if interested: https://www.evolutionm.net/forums/ev...ttery-evo.html
Old Sep 21, 2021 | 04:31 PM
  #1151
ViciousLSD's Avatar
yeah could be shipping damage. every time i disconnect the + terminal i see the post flex, I think i broke my 5yo that way. so now I use 2 hands, one to hold the fuse block thing. then again i have no idea who sells on amazon
Old Sep 21, 2021 | 06:51 PM
  #1152
Yep, pretty sure it was shipping damage. Both the PC680's were shipped in a form fitting cardboard box w/no padding. In any event the Hitachi battery has been a good alternative
Old Sep 21, 2021 | 07:32 PM
  #1153
kaj's Avatar
kaj
If anyone is looking for other battery options, I bought my Stinger about 5yrs ago and it's still working. It's on the tender 11mos out of the year, not sure if that's why. I can get a model number, if anyone is wanting to check it out.
I'm pretty sure it's this one:
Amazon Amazon
Old Sep 21, 2021 | 08:33 PM
  #1154
ViciousLSD's Avatar
that looks rebranded PC680, for the boom box (capacitor) crowd
Old Sep 22, 2021 | 12:21 PM
  #1155
kaj's Avatar
kaj
Possibly. It's lasted a number of years so figured I'd post it up for everyone.
