help: check engine light from bung??
Old Dec 15, 2008 | 09:03 AM
pekpekbuster's Avatar
so i was gonna install my test pipe last weekend but then i realized i needed some longer bolts & nuts, cuz the cat was already threaded. the test pipe wasn't.
anyway, i decided to leave the bung i installed for the o2 sensor still in the exhaust, with the stock cat still in, till i get the right hardware. now i got a check engine light. is this normal? will it go away once i get the test pipe in?
Old Dec 15, 2008 | 09:05 AM
wevo1985's Avatar
just pull the fuses and clear it when everything is together
Old Dec 15, 2008 | 09:07 AM
which fuses?
Old Dec 15, 2008 | 09:13 AM
wevo1985's Avatar
under the hood fuse panel has 2 fuses for the ecm. one is 20amp and one is a 15 i believe. pull both of them out for 10sec and the light will clear and your ecm will be reset.
Old Dec 15, 2008 | 09:16 AM
ok, coo i'll try that. thanks dood.
...i'll let u know what happens.
Old Dec 15, 2008 | 09:22 AM
wevo1985's Avatar
ok
Old Dec 15, 2008 | 11:49 AM
cool, it went away for now. does that mean my o2 sensor may still be ok?
Old Dec 15, 2008 | 11:52 AM
Ph3n1x's Avatar
The code was most likely a "flow" code due to the bung being in place. It will come on again until you put the test pipe in.
Old Dec 15, 2008 | 11:56 AM
phew...ok, cool i hope so. thanks.
Old Dec 15, 2008 | 04:00 PM
well, it just came back on after driving for 30 mins. hope that's all it is.
evo854880
Apr 17, 2012 09:10 PM
elmark44
Sep 28, 2010 10:22 AM
RedEvoxGSR
Jun 15, 2010 10:47 PM
BlackonBlack2
10
Sep 28, 2008 09:47 AM
race17k
24
Feb 7, 2007 05:34 PM
