check engine light comes on sometimes?
Old Dec 5, 2009 | 07:08 PM
speedfreak24's Avatar
Ok so i bought a turbo back exhaust with a test pipe last summer and got my evo 9 tuned. Then i had to get it inspected last april so my friend who did it said buy a spark plug anti fouler i did and installed it for the o2 sensor. the light went away got my stickers everything was cool. but now sometimes when it rains alot the light comes back on. My evo runs fine, knock on wood, so i figure its just the sensor still throwing the code. The light will go off after a day or two. Anyone have the same problem? or should i really get this looked at?
Old Dec 5, 2009 | 07:14 PM
_mcjonnyp's Avatar
you can disable the rear o2 code in the peripheries or with the resistor mod
There are writeups on both, just search
Old Dec 5, 2009 | 07:15 PM
FedEvo8's Avatar
Just to be sure, check what codes the ECU is throwing. If it's a P0420, it's the cat.
Old Dec 5, 2009 | 07:38 PM
ok how can i check myself not to sound like a newb or do i have to take to a mechanic? it will prob be off next time i start my car happend like 4 times since april.
Old Dec 5, 2009 | 07:42 PM
lelek's Avatar
just buy cheap obd2 reader ,
Old Dec 5, 2009 | 07:50 PM
yeah i should invest into one of them anyways. how much they run?
Old Dec 5, 2009 | 10:28 PM
evolotion357's Avatar
I picked one up from Pepboys for like 30 bucks. All it does is give you the code number which you can look up with the software that is included with it or via the internet.
I would try to link you one from their site but it is god awful. I am sure you can find one at any autocare place such as Autozone, Pepboys, hell.. maybe even Walmart.
Old Dec 6, 2009 | 12:44 AM
SmurfZilla's Avatar
If you have a laptop use the scanOBDII for free. If you have access to a tactrix cable then you pull the code easy peasy and clear it. If not you local automotive chain should be able to pull the code.
EvolutionX9817
May 22, 2015 10:57 PM
prack7
Aug 8, 2014 09:13 AM
UGOTBUSLINKD87
May 19, 2011 04:54 AM
asahlot
Lancer Troubleshooting
10
Aug 20, 2010 06:20 PM
stikillller
May 9, 2008 10:25 PM
