Help??????????????
Old Jul 2, 2010 | 04:35 PM
hawkeyez's Avatar
Help??????????????
Maybe somebody can help me with a problem. I have a 2005 EVO VIII and I took off my EVO IX Bov to try a Greddy RS Recert for a few minuets and did not like it. I then Switched back to my EVO IX bov and the car ran nice until I hit the factory 20 psi and then it runs like crap. The car only runs like 20 mph and cant build boost. I hooked everything back the way it came off. I only unhooked one vacuum line. Please help.
Old Jul 2, 2010 | 04:37 PM
SLO-EVO's Avatar
another hose fell off from somewhere.
Old Jul 2, 2010 | 04:38 PM
ak47po's Avatar
Try disconnecting the negative battery cable for a few minutes to reset ecu,see if that helps.
Old Jul 2, 2010 | 04:39 PM
hawkeyez's Avatar
Ok because I only disconnected the positive. Ill check the hoses as well!!
Old Jul 2, 2010 | 04:51 PM
rburris28's Avatar
If it hit 20 psi once, then won't accelerate or build boost, you blew an intercooler hose off.
Old Jul 2, 2010 | 04:57 PM
FQ-300's Avatar
ak47po is correct, disconnect the negative terminal from your battery. I would be safe and wait about 10 minutes (overkill for many, but that's what I would do). Re-check the vacuum lines. If the intercooler hose blew off, you would know right away (stumbling, rough acceleration). Good luck.
Old Jul 2, 2010 | 05:23 PM
milford's Avatar
yep ive had this happen. i clean the hoses with alcohol before i tighten down the clamps to help them from slipping due to blow by oil getting all over them and not getting a good straight clamp.
Old Jul 2, 2010 | 07:27 PM
cartuner08's Avatar
I've had this also, just on my eclipses 4g63. It happened to be a silicone coupling hose that came out of the IC that had a 2-3 in. tear in it
Old Jul 2, 2010 | 08:28 PM
hawkeyez's Avatar
Thanks guys. The Car is in the garage with the hood up. I will check these issues out tomorrow morning!!!!!!! Any more ideas keep them coming. Before this I never once had an issue with this car. This is a bummer...
Old Jul 2, 2010 | 08:39 PM
DuderMagee's Avatar
going by what has been done and the symptoms
it sounds like a massive boost leak like everyone else has said
I had a FMIC pipe come off my old sr'd 240 and the same thing happened
Old Jul 2, 2010 | 09:09 PM
ineedspots's Avatar
would a bov being intalled backwards cause this issue? maybe that?
i know you said you put it back the way it came out, but something like that could just be a d'oh moment.
Old Jul 4, 2010 | 12:12 PM
hawkeyez's Avatar
Well just wanted to say that I got the problem fixed. Found out that there was a small slice on a vac line and the hose was kinked a little bit. Replaced the hose and she is back to normal!!!!!! Thanks for your help!
Old Jul 4, 2010 | 12:16 PM
EvoFredo's Avatar
thats good that you found the problem. sounds stange that a small slit caused all that. so you didnt find any blown off intercooler pipes. good job anayway.
Old Jul 5, 2010 | 09:33 AM
hawkeyez's Avatar
Thanks. No I checked and there were no blown off intercooler pipes which was def a plus! Now looking to get tuned either this week or next.
Vivid Racing
12
Jul 30, 2014 03:40 PM
bigplansnocar
Dec 9, 2011 08:49 PM
MR:PartyPete
Nov 5, 2009 11:12 PM
X_Evo
17
Nov 11, 2007 06:39 PM
wprettyboy
27
Oct 19, 2004 10:44 PM
