E85 vs 93
Old Feb 22, 2011 | 08:38 AM
QUANLOCO's Avatar
O
Originally Posted by __pg
Can someone explain the process of using the switch? If the gas light is on with E85 in the tank, can you simply just flip the switch and fill up with 93 and vise versa? Or is them some crazy process of emptying the tank?
You need to completely empty ur tank I would advise against mixing fuels even by the smallest margins.
Old Feb 22, 2011 | 08:44 AM
__pg's Avatar
Originally Posted by QUANLOCO
O
Thanks. That just makes me think that having the switch would be annoying. I'm also assuming manually emptying a tank isn't the easiest thing to do.
Old Feb 22, 2011 | 08:45 AM
Broham's Avatar
where i live e85 is 80 cents cheaper. at the end of the day, e85 is where its at. its like getting race gas for dirt cheap and it keeps your motor clean and knock is kept away. e85 is what you should run but get a beater car for loooong commutes if you can.
Old Feb 22, 2011 | 08:46 AM
QUANLOCO's Avatar
Originally Posted by Evofletch
I've been thinking about going e85 but not sure I know everything I need but can't decide so if you guys can let me know what you think
I am going to make the switch in the spring as well. To be safe u need to buy a e85 tester, I got.mine from buschur racing. They cost $15.00 plus shipping and its simple to use for accurately making sure it is 85% eth. Go to buschurracing.com and check it out.
Old Feb 22, 2011 | 08:49 AM
QUANLOCO's Avatar
Never tried emptying my tank but it doesn't sound fun. From what I heard there are two plugs at the front of tank but not sure.
Old Feb 22, 2011 | 09:12 AM
mission664's Avatar
so if its not 85% dont do it? i thought in the winter the blend has more gas in it. or do you NEED two maps when switching?
Old Feb 22, 2011 | 09:35 AM
thepoint4life23's Avatar
I have e85 all around my house like 2 or 3 places with in 5 min. but my car is almost stock is it worth the change for me right now
Old Feb 22, 2011 | 09:43 AM
saxon's Avatar
^^ its worth the change if you want more power, upgrade your fuel system and gain a good amount of power
Old Feb 22, 2011 | 09:45 AM
cheb evo's Avatar
No need to get under the car. Simply unhook the fuel return line from the fuel rail and let the car idle, with the fuel line directed into a gas can. Only takes a few minutes if you let the tank run pretty low on the day you are planning to change out.
Old Feb 22, 2011 | 09:47 AM
cheb evo's Avatar
Take a look at the minimal mods in my signature vs. the incredible gains in HP and TQ I gained with a tune. I would definitely say the switch is worth it. In addition, depending on what exhaust you are running, the smell is much better with E85 vs. 93 octance.
Old Feb 22, 2011 | 09:57 AM
Evofletch's Avatar
I'm just gonna go e85 lol gas stations are right Down the road I wish shell had e85 I work at shell so I'm gonna ask If they've ever thought about getting e85 well right now it would be e70 cause I live in Chicago
Old Feb 22, 2011 | 10:02 AM
dek0026's Avatar
Originally Posted by MuslimEvoFreak
Yeah I wonder if the trade-off is worth it. I will pay less for E-85 but get have a lower MPG...hmmm...it is readily available in my area too.
See that would kill me! I average 260-280 on a full tank if I don't boost. I fill up twice a week...$100 total.
it's worth it. you'd just need to fill up one more time at the end of the week to get through friday.
Originally Posted by Bad Company
I just bought all my gear to get ready for my switch to E85 come spring. New fuel pump and bigger injectors followed by a tune and I'll be good to go! I think I'll switch back to 93 during the winters though, seeing as it's basically E70 in WI from what I hear....
i've been running it all year round. the last time i tested it was when they were transitioning from summer blend to winter blend and it was 77%. right now it's likely 70% and no issues like pulling timing/knock. it still runs smoothly...it all comes down to how it was tuned. i was tuned on winter blend a bit rich for e85 with the intention of it leaning out in the summer time. working out well so far.
emptying the tank is a good way to be absolutely sure of what you have in there but most people i know run the tank low with the understanding that they have to run through a few tanks before you're running pure 93 or e85.
i haven't switched back because it take a bit more of a commitment but if i got stuck and needed gas it wouldn't be a big deal really.
i got one from summit for the same price. it's really easy to use and definitely worth it.
you could run winter and summer blend on the same tune if it is tuned to allow for it.
winter blend isn't always optimal for hard driving but that's why god invented datalogs.
i love the smell of e85. it's very distinct.
(but what the hell do i know? i just some dude on the internet who apparently believes he's the e85 expert now)
Old Feb 22, 2011 | 10:04 AM
dek0026's Avatar
i have a link to that shows all the grades of e85 for every month by state. it's on my home computer and i will edit this post with it when i get home.
Old Feb 22, 2011 | 10:41 AM
Evofletch's Avatar
Thank you
Old Feb 22, 2011 | 11:02 AM
TxEvo8's Avatar
Some good info in this thread and some not so good. You DO NOT need to empty your tank when switching, just run it low, and fill up with the other type of fuel. If your tuner knows what he is doing, then the summer/winter blend issue is moot. I race on winter blend probably 3-4 times per year, never had an issue.
It is ABSOLUTELY worth if for anybody that has access to the fuel, even if you are bone stock. The mileage is a little bit lower, but the additional power makes it a no brainer. E85 is the good stuff!!
