View Poll Results: Do you have interior rattles in your evo?
no
66
13.55%
1-2
286
58.73%
3-5
81
16.63%
5+
54
11.09%
Voters: 487. You may not vote on this poll
Rattles & Squeaks Inside Your Evo [ALL THREADS MERGED]
Old Mar 7, 2007 | 12:15 PM
  #166
braille's Avatar
Curt941 - i have that same rattle you described in my IX GSR. Could you let me know how it goes after you fix it? Thats the only noise that i have besides the normal brake squeal. Other than that, no complaints. thanks
Mike
Old Mar 7, 2007 | 02:28 PM
  #167
jab_phoenix's Avatar
i only have rattles when i turn up my system heh heh :-D
Old Mar 7, 2007 | 02:55 PM
  #168
styles's Avatar
I hate it when my breaks squeak.
Old Nov 24, 2007 | 11:28 PM
  #169
Viciouslord's Avatar
i just got a new rattle/creeking...
dash board near windshield creeks over speed bumps and rough roads, no matter what speed...
this started recently, i have had coilovers installed for a while now with no noise at all....
Old Nov 24, 2007 | 11:39 PM
  #170
Rustyreno's Avatar
Now that it is cold everything is squeaking and rattling in my car. The breaks, dash, everything. I am going insane every time I get in my car.
-Andrew
Old Nov 26, 2007 | 11:54 AM
  #171
bump for solution.
Old Dec 1, 2007 | 03:26 AM
  #172
Ttt!
Old Dec 1, 2007 | 04:02 AM
  #173
dRifT iT's Avatar
when its wet out/ moisture in the air, i have a little squeek noise going over bumps. I coudlnt figure it out so i got out of the car and started pushing down on the fenders, i got the sound. I think its just the rubber seals or something that make a noise when they move because of the moisture... Oh well...
Solution for all = Turn up the radio!!!
Old Dec 1, 2007 | 04:17 AM
  #174
dino21's Avatar
sometimes yes sometimes not!!!! im confused
Old Dec 11, 2007 | 06:59 PM
  #175
Ttt
Old Dec 11, 2007 | 07:17 PM
  #176
Mike@JTuned's Avatar
I've got rattles galor in my 9. Stout motors, crap build quality around it.
  #177
supwiddiss's Avatar
If it's a styrofoam cooler type squeak coming from the lower dash area and you are going crazy, try what I just did. I went to the car wash and sprayed the rack and pinion area along the firewall (lightly). The noise went away until the car dried.
I had washed it in the past and the squeak was noticable before I tried wetting the R&P.
The next time it's in the air I'm going to try spraying the bushings with silicone and see if the damned squeaks go away.
I have an 06 MR and have had quite a few interior trim pieces off, one at a time, trying to find this particular squeak. It's not inside. Turning the radio up seems to make it less noticable. Go figure.
Old Dec 11, 2007 | 07:29 PM
  #178
72Tornado's Avatar
I can attest to the interior settling in and the squeaks going away as time goes on. I was horrified at the squeaks and rattles that started appearing as early as 800 miles on my car, enough so I took it to the dealership a couple times and got a few things fixed. I'm at 11,000 miles now and the interior is the quietest it's been since
Old Dec 11, 2007 | 09:42 PM
  #179
VT Mitsu's Avatar
Originally Posted by Volunteer
FYI.
I brought mine into Mitsu last week for the annoying door screaching and cracking. I use to be able to drown out the sound with the radio, but then it got to be a battle and had to bring it in. Mechanic said there is a TSB for the door weather moldings, its the sound of plastic on plastic. Order both and should be in this week. Also has a TSB for the door handle linkage on the inside of the door, they put in felt lining behind it to stop it from bumping the metal shell of the door. At least they addressed all my issues, the dealer has been great.
Do you have the TSB number for the weather moldings? I have the same noise, but the dealer is saying that there is no TSB.
Please help
I'll try to get it for you, its very annoying especially over a period of time when its rubbing platic on plastic. . They put the new weather stripping on both sides and its quiet as can be. I'll see if my buddy at the dealership can fax it to me I'll scan it and post it here.
Any chance of still getting this? PLEASE !?!?!?! :]
Old Dec 11, 2007 | 10:56 PM
  #180
Xolition's Avatar
Originally Posted by tra03
I drove my brand new Evo out the door last Tuesday, with 11 miles on it (hooray!)
Almost immediately I hear this rattle that is coming from behind the glove compartment, or somewhere inside the dashboard behind the glovebox, and I do not have anything yet inside the blove compartment.
It sounds like a loose wiring harness dangling against a plastic surface, enough to make a constant but faint rattling noise.
But at hghway speeds, the rattling noice is drowned from the road noises.
Either that, or turn up the hifi volume.
Or rev the engine ;-)
It is a minor annoyance...and I agree with some posters that this is part of the *allure* of owning an Evo....
I have the same glove box rattle (and no it's not anything inside of it) which started after my stereo/alarm install. Seems like if you get your dash pulled/etc. you're going to end up with a few. Just have to turn the music up now
