View Poll Results: Do you have interior rattles in your evo?
no
66
13.55%
1-2
286
58.73%
3-5
81
16.63%
5+
54
11.09%
Voters: 487. You may not vote on this poll
Rattles & Squeaks Inside Your Evo [ALL THREADS MERGED]
Old Dec 11, 2007 | 11:32 PM
  #181
gixxer6's Avatar
Originally Posted by stvbreal
I had the some noise. I got so pissed off that I just beat the hell out of it with my fist. Noise is gone now.
haha ya i' try this before all else^^
Old Dec 12, 2007 | 06:08 AM
  #182
Viciouslord's Avatar
Originally Posted by Viciouslord
i just got a new rattle/creeking...
dash board near windshield creeks over speed bumps and rough roads, no matter what speed...
this started recently, i have had coilovers installed for a while now with no noise at all....
Originally Posted by supwiddiss
If it's a styrofoam cooler type squeak coming from the lower dash area and you are going crazy, try what I just did. I went to the car wash and sprayed the rack and pinion area along the firewall (lightly). The noise went away until the car dried.
I had washed it in the past and the squeak was noticable before I tried wetting the R&P.
The next time it's in the air I'm going to try spraying the bushings with silicone and see if the damned squeaks go away.
I have an 06 MR and have had quite a few interior trim pieces off, one at a time, trying to find this particular squeak. It's not inside. Turning the radio up seems to make it less noticable. Go figure.
well to add to the problem... i noticed the creaking sound after i recently went off road before that i had no noise.... you think it might be an alignment issue?
Old Jun 5, 2008 | 05:24 AM
  #183
Malik_EvoIX's Avatar
every time i hit a bump a noise like a Bird churping. pretty annoying...
Old Aug 27, 2008 | 01:56 PM
  #184
rwalker's Avatar
so, after trying to search out results for squeaks, I'm still on the lookout for help.
anyone have any help on:
the rear window/speaker deck making a aluminum sheet twang?
far left side of driver side dash by driver door?
The rear deck hum/vibration seems to resonate at a certain rpm range.
Thanks
Old Aug 27, 2008 | 06:04 PM
  #185
Vibrant's Avatar
Aside from the typical valve noise, the walbro whine, and that clunk the shifter makes (loud), the only noise I have that I cant explain, is coming from under the cam gear cover. I've taken the cover off, and dont see anything out of the ordinary. The noise is loudest before the car is warm.
Old Aug 27, 2008 | 06:54 PM
  #186
Zodiac13's Avatar
i got some weird metal rattling noise that sounds like its coming from in front of the passenger seat like at the tire or something but its been like that for well over a year. it pretty much just happens when i go from a stand still and make a right or left turn. anyone know what it could be or if i have anything to worry about? thanks in advance.
Old Aug 28, 2008 | 11:22 AM
  #187
Evo9"Miss Rose"'s Avatar
funny i just got that noise right when i got my car back up and running?!?! (7months down time) prolly has something to do with not running my car for awhile!! ahh well a little bit of music will to the job
Old Aug 28, 2008 | 07:20 PM
  #188
rwalker's Avatar
found my rear rattle in trunk. two metal rods up high near decklid. taped em, all is well
Old Dec 10, 2009 | 10:15 AM
  #189
kyoo's Avatar
I have this! I'm not entirely sure when it started, fairly recently, but I'm getting a new windshield soon so I plan on taking care of it then and there. I think it's possible it could be some sort of plastic clip rubbing or something along those lines. It's really random for me though.
Old Dec 10, 2009 | 11:25 AM
  #190
LuisIX's Avatar
Originally Posted by rwalker
so, after trying to search out results for squeaks, i'm still on the lookout for help.
Anyone have any help on:
The rear window/speaker deck making a aluminum sheet twang?
Far left side of driver side dash by driver door?
Thanks
i got exact same problems also have 1 under the steering column
Old Feb 4, 2010 | 08:57 PM
  #191
kyoo's Avatar
bump for this. drove my car again for the first time in 5 months and this squeak was there - the only noise I've ever had in my evo -
A squeak like two styrofoam pieces rubbing against each other every time I go over a bump - I would think it's suspension but i swear it's coming from the inside. It sounds like it's coming from directly in front of me, inside the dash somewhere.
help! who takes care of this? where is this noise coming from!!
Old Feb 5, 2010 | 12:39 AM
  #192
boostin350z's Avatar
i got mad rattling, sounds like a loose shield or somethin
Old Jun 1, 2015 | 12:34 AM
  #193
djslik408's Avatar
Im bringing this thread alive! I have this annoying rattling aounds coming from my passenger side when i step on the brake fairly hard.
PriusRepellent
Feb 7, 2016 06:54 PM
Gracing2000
Apr 25, 2010 08:12 AM
donmeca2020
Jun 9, 2009 09:54 AM
bluewaterDEMON
Lancer Troubleshooting
12
Aug 27, 2007 07:43 PM
