Grinding AFTER start.
Old Sep 19, 2011 | 05:23 AM
SaulHudson's Avatar
I've got a IV and after starting there is light, grind-like sound. It is not loud and it is not long. Immediately after it turns over it will last for maybe 1 sec. I know it could be the flywheel not disengaging from starter, can anyone think of anything else?
Old Sep 19, 2011 | 05:32 AM
evoxsi's Avatar
does it make a difference if the clutch is pushed?
Old Sep 19, 2011 | 05:34 AM
SaulHudson's Avatar
I do always start it with clutch depressed, but I tested it and it seems to occur when it is not in too.
Old Sep 19, 2011 | 05:56 AM
evoxsi's Avatar
ok i had grinding on startup when i would press the clutch and it ended up being broken splines on the clutch.
Old Sep 19, 2011 | 09:21 AM
ProPilot04's Avatar
I would say its the starter. The starter motor uses flyweights to move the gears onto the flywheel during the "cranking"... if the weights are sticking a bit, or the motor is just generally old, it may need to be lubed up a bit.
I'd suggest getting it off of the car, inspecting it, and lubing, or replacing it as necessary.
Old Sep 20, 2011 | 12:51 AM
SaulHudson's Avatar
I also first thought the starter too but after more tests, the sound is near definitively coming from the turbo area. I know the turbines get loose and such but its still pushing 21lbs of boost. Any ideas?
Old Sep 20, 2011 | 03:11 AM
evoxsi's Avatar
take ur intake off and check for rubbing on the compressor cover. u can also push on the center of the compressor blades to c how much movement there is.
Old Sep 20, 2011 | 04:00 AM
civicej8's Avatar
the starter is right under the turbo. if you post up a vid we can proly tell for sure if it is the starter.
Old Sep 20, 2011 | 09:11 AM
ProPilot04's Avatar
Right... but a starter is "more likely" a source of grinding associated with a start than a turbine.
Either way, pull ur intake off and LOOK at the turbo to see if it looks like its grinding. Check the fins, see if theres a ton of play, if you don't see anything, then move onto yanking the starter off and seeing what the teeth on the bendix look like.
Old Sep 20, 2011 | 09:17 AM
civicej8's Avatar
or when you turn on the car just hold your key to the starter position a little longer than normal, and see if the grinding is still making that sound. if that makes sense.
Old Sep 21, 2011 | 06:01 AM
SaulHudson's Avatar
Sorry for late reply. We have a typhoon here. Here is audio of 3 starts. The noise is most prevalent on the 2nd start but is present on all 3. The morse code sounding stuff is not part of this.
http://www.youtube.com/watch?v=8uGDk251h7g
SaulHudson
Nov 10, 2017 06:35 AM
Ralliheart
May 4, 2015 12:02 PM
ice1874193
Jul 1, 2012 02:22 PM
fabcas311
Jan 1, 2011 04:23 PM
EvoStormTrooper
Mitsubishi TC-SST Discussion
Aug 8, 2010 11:34 PM
