Sea Foam
Old Dec 17, 2011 | 12:21 PM
  #106
twabtoxer's Avatar
cant wait to do this..... clean out the injectors and my neighbors will think snoop dog is shooting a video in my garage LOL
Old Dec 17, 2011 | 12:41 PM
  #107
CurseDSM's Avatar
Do it outside please do not do that in the garage that stuff I'm sure isn't good to breathe
Old Dec 17, 2011 | 12:48 PM
  #108
chu's Avatar
chu
Just did it to my car. First time, with 137k on the odo. Didn't getting near the amount of smoke any of you guys are getting. Got a few puffs when I poured some into the vacuum line, but that was it. Guess its mad clean in there!
Old Dec 17, 2011 | 12:51 PM
  #109
CurseDSM's Avatar
I do mine a few times myself. I will do it origionally drive it a day or 2 do it again and again till it doesn't smoke anymore. I will use a whole bottle just in the vac lines over a week or so and it works well specially in my truck
Old Dec 18, 2011 | 11:39 AM
  #110
DecepticonsMR's Avatar
just did mine and I already feel a huge improvement...also clean out your MAF too!
Old Dec 18, 2011 | 03:08 PM
  #111
WolfsFang's Avatar
yea i cleaned my MAF also and noticed a difference, going to clean my throttle also tomorrow. For people with high milage i suggest getting a friend and letting him/her push the throttle all the way and see if the throttle opens all the way since over time the wire can stretch. The worse iv seen is the throttle only open 25%.
Old Dec 18, 2011 | 09:35 PM
  #112
tiggeryellow1's Avatar
Veteran: Army
Originally Posted by cursedsm
No you will want to get it out of the system before you drive it. It will blow smoke out the *** end like spyhunter for 15 mins or so pending on how much you use and how much of the stuff was cleaned out. Once it stops smokeing then you can drive it.
Originally Posted by Ramonski
I think what tigger was referring to were the directions on the back of the can. It says that once you pout 1/3 pint into the vacuum line you shut the car off for 5 minutes and the turn it back on. I just did it last night and I remember reading the directions like 10 times before I poured it anywhere lol
Ok Soooooo after this I think once I pour the foam down the vac line I will let all the smoke clear before I pull off onto the street this time vs. shuting the car off for 5 minutes then going out and jumping on it. We shall see how it goes.
Old Dec 19, 2011 | 08:38 AM
  #113
05raslw's Avatar
has anyone tried sea foam for the tranny yet. if so what does it actually do
Old Dec 19, 2011 | 07:26 PM
  #114
ABNEVO's Avatar
330 whp @24psi, my car only gets 220 miles per tank of gas on daily drive. I'm going to try this tomorrow morning. I hope it's a win win outcome like everyone else.
Old Dec 19, 2011 | 07:34 PM
  #115
CurseDSM's Avatar
I already answered that it would prob **** up your tranny being you should be changing the fluids in it every other oil change
Old Dec 20, 2011 | 05:56 AM
  #116
High_PSI's Avatar
Why woudl you change the fluids in your tranny? I got 108K on my VIII, changed the fluids at 60K along with the timing belt.
My IX MR had the fluids changed a month ago at 90K and it was still clean.
I would immagine that if you track your car ALOT and bang your gears to get some trash in there then yes change your fluid a lot.
Oil changes too, 5000 MIN you dummies.
Old Dec 20, 2011 | 07:30 AM
  #117
s2evo's Avatar
Used this on all of my cars with wonderful results. Better throttle response, mileage, and power. My neighbour wasn't really happy about the smokeshow though.
Old Dec 20, 2011 | 07:47 AM
  #118
chrisw's Avatar
after reading this thread I tried this on my daily driver, a 99 mercedes c230 kompressor.
This car has 168k miles on it, and the previous owners didn't even try to take care of it. I figured that a sea foam treatment would really help clean the intake and combustion chambers.
After the sea foam treatment, the engine appears smoother, revs a little better, but my millage has dropped by more than 1mpg
I may have contaminated the MAF sensor with the sea foam, I hope that's it. I might try more in the gas tank to clean the injectors, and I might try treating the intake again for schist and giggles.
Old Dec 20, 2011 | 09:20 AM
  #119
Veteran: Army
Do it! I have treated my intake and gas tank the last 2 fill ups and I am prolly gonna do it one more time. The smoke after dumping the foam down the vac line this time seemed to be a lot less on this second treatment so on the next one it should be next to none I think... but we shall see. I also put about half a can in the engine last night and I plan on changing it today or tomorrow. It's crazy but the oil actually looks a little cleaner after I put the foam in the motor... anyone else noticed this?
Old Dec 20, 2011 | 12:01 PM
  #120
BoostINurI's Avatar
If you dumped the seafoam down the intake "same pipe that goes to air filter " you did it wrong. It goes directly into intake manifold via vacuum line. You might have toasted your maf.
GL!
