Reverse issue on my 6 speed
Old Jan 3, 2012 | 04:01 PM
clubEVO93's Avatar
Where did you zip tie the upper pipe to? I don't see where you could
Old Jan 3, 2012 | 04:27 PM
CJ2X's Avatar
You can use the hole from the battery tray (on the frame). You shouldn't have to use it since it's for the stock battery set up.
Old Jan 18, 2012 | 08:29 AM
Hardware's Avatar
That's what I did. It's more or less pulling the pipe to the drivers side of the car, but it's just enough to help.
Old Jan 16, 2013 | 06:37 PM
racas's Avatar
hey guys, i'm looking at an evo fs, and the owner says "it goes into reverse but pops back out when let off clutch. so no reverse. doesnt need a new trans, syncros is just bad for reverse"
it an 03 evo 8. What do you guys think about his(seller) diagnosis? It sounds like the same problem the OP had, but turns out it was OP's UICP.
CaptainSquirts
May 17, 2016 08:35 PM
jmsrt4
23
Jan 30, 2014 02:10 PM
seishichiro
Mitsubishi TC-SST Discussion
21
Feb 12, 2011 09:16 PM
Darkn3s
Dec 29, 2009 12:38 PM
number 8
Jul 28, 2008 01:12 PM
