Evo 9 randomly not starting
Im telling you this is your problem. Worse case scenario you buy a switch a new switch from Mitsubishi or Ebay for $60 and if it doesn't work return it. (Only if new and they allow.) You can find them used in part outs pretty cheap, im 99.99% sure THIS IS YOUR PROBLEM.
For the coils i just meant do a quick visual inspection by removing the spark plug cover and making sure all the connectors are ok and that the wire boots are all properly installed over the plugs. Did his problem start occurring shortly after you did your plug change this year?
Mine used to crank aswell until it got worse and worse and eventually ended up not starting more than it started. At the early stages it cranked but would not turn over.
Thanks
my friends car are having the same problem last few month back. then he change the ignition switch inside the key hole and the problem solved. now my 06 e9 gsr facing the same problem. but my problem come and gone. maybe 3time per month. so do u manage to fix it?
OP, check out the thread i made on a similar problem i had a while back
https://www.evolutionm.net/forums/ev...-no-start.html
my issue was my sparks were not firing because the carbon build up was so built over time from cranking too much, the injectors sprayed too much fuel into the combustion chamber...the issue was my injectors were stuck open, i just cleaned my spark plugs and bought new injectors from a fellow evom member and it cost me 85 bucks total lol toyest just take your coil plugs out, remove spark plugs, get a BBQ lighter and try igniting the combustion chamber, if a huge blow torch like flame shoots up. there is your problem...injectors...just because the sparks dont fire it doesnt necessarily mean its them. Let us know hoe everything turns out op hope this helps...
IGNITION SWITCH!!! My 8 had the same issue. I will dig up my thread and post it in here for you.
The GOOD news is though, an ignition switch is cheap (can find one on here for $50), very easy to change, and you DON'T need to get a new key cut.
Edit: Here is my thread I originally posted last year.
https://www.evolutionm.net/forums/ev...lp-advice.html
I told ya so
So my issue is getting worst and worst
I think i have finally narrowed it down to injectors. When it doesnt start now i do a "flood clear" (push pedal to the floor before cranking) for a few seconds and usually it will start during this process or the second or third time trying to start it normally. It works everytime. So i think i have leaky injector(s) that will intermittently leak.Sounds like this happened to at least one other member. Has this happened to anyone else?
Anyone have a spare stock set of injectors for sale?
I had my ignition fuse go out on my car randomly. The car would just turn and turn but never start. Assumed the absolute worse. Once I found the fuse I was relived. Its in the fuse box bottom left of the steering wheel
michaellw
12
May 5, 2016 07:21 AM
hooliganSKATE
Dec 24, 2015 01:57 PM
