Mitsubishi Evo TSB May 2013 [MERGE]
Old Sep 1, 2015 | 08:19 PM
  #76
Klaiceps's Avatar
<p>Sorry for bringing this thread back but what exactly is the dealership's procedure for updating the ECU? The local dealership here is messing up the ECU updates on Evos. The cars are unable to start after the update.</p>
Old Sep 2, 2015 | 06:49 AM
  #77
Construct's Avatar
I'm not intimately familiar with the dealer reflashing tools, but the first thing that comes to mind is that they're not correctly transferring the immobilizer code to the newly reflashed image.
Obviously you'll want to avoid that dealership, because I'm sure the proper procedures are carefully spelled out in whatever documentation their techs failed to read.
Does anyone have a dump of the new ROM image by chance?
Old Sep 2, 2015 | 07:23 AM
  #78
bboypuertoroc's Avatar
Veteran: Army
This.
Also, since he's in Hawaii, he doesn't have much of a choice for Mitsu dealerships. One, to be exact (unless something changed since I lived there).
Don't even waste your time taking it in. Just get a proper tune... excessively rich problem gone.
Old Sep 2, 2015 | 10:42 AM
  #79
Klaiceps's Avatar
I'm not intimately familiar with the dealer reflashing tools, but the first thing that comes to mind is that they're not correctly transferring the immobilizer code to the newly reflashed image. Obviously you'll want to avoid that dealership, because I'm sure the proper procedures are carefully spelled out in whatever documentation their techs failed to read. Does anyone have a dump of the new ROM image by chance?
bboypuertoroc is correct. There's unfortunately only one Mitsubishi dealership here. That's exactly the step that this dealership is not doing right. Long story short, there was an Evo IX there that just would not start after a "failed" reflash. The tech stated he attempted to reflash but could no longer communicate with the ECU, which I thought seemed odd. I hooked up my laptop and guess what.... I was able to communicate with the ECU. I downloaded the ROM image and poked around for a bit. I disabled the immobilizer, reflashed the ECU, car fired right up. A couple months later, I get a call from them asking me to help them out again with another Evo IX. Since I was nice enough to help them out the first time, I kindly asked for some sort of compensation for my time if I were to bail them out this second time. I'm still waiting for a call back from them.Oh and attached below is the updated 88590016 ROM that Mitsubishi is reflashing into Evo IXs.
File Type: bin
Old Dec 15, 2015 | 01:09 PM
  #80
KnightRider9's Avatar
Really old thread but I have "fun" story to add . I took my Evo in today due to some weird fluttering air sound. They said "hey, while it's here, we should do the two outstanding recalls on it." I say go ahead.
I get a call this afternoon saying they fixed the air leak issue (pipe clamp came off), but there's still no boost and the turbo needs replaced. $4k. I'm passing on that. I'm not spending $4k for a stock turbo.
"Oh, and we did the PCM flash. Two things can happen when we flash it. #1 it flashes and all is well. #2 it fails and burns up the computer. you got #2. Don't worry, it's cost is covered by the recall. We just have to order a new computer from Japan now."
Estimated delivery date of the computer is Feb 16, 2016. Today is Dec 15, 2015. WTF???
Old Dec 15, 2015 | 02:32 PM
  #81
Biggiesacks's Avatar
Ouch that sucks, I hope they are at least hooking you up with a free rental. Big **** up on that dealers part though. You would think they would check how hard it was going to be to replace the ecu before doing something that may brick it. There are ways to unbrick an ECU if you are interested, check out the ECUFlash subforum. There is a sticky with all the important threads, so you don't have to wade through too much stuff.
Old Dec 16, 2015 | 07:13 AM
  #82
Construct's Avatar
Many of us flash our ECUs all the time without issue. I wonder exactly what they did here.
The two month lead time is unacceptable. I'd buy a used ECU off of the forums or eBay and make the dealer reimburse you for it. You'll have to disable the immobilizer code or make the immobilizer code match your keys, but that's easy enough.
Old Dec 16, 2015 | 08:41 AM
  #83
Klaiceps's Avatar
They may think they bricked the ECU but it could be they just forgot to input the immobilizer code. If you know how to navigate ECU Flash, you could upload a stock map to your ECU and disable the immobilizer. It should start from there. Then you can tell them to pay you for fixing your own car.
Old Dec 16, 2015 | 10:34 AM
  #84
Thanks for the info guys. When I go pick up my free rental car today, I'll mention the immobilizer code. I can't imagine a way for them to actually damage the computer while flashing it assuming they physically hooked it up correctly. They said it was the 2nd car in 6 months that had this issue when flashing it. So like you said, it's likely just immobilizer related.
Of course, I may prefer to drive a rental during the crappy winter months (Ohio). I'd rather not risk wrecking the Evo in the snow, replacing tires, and I'd still have to replace the turbo anyways, although a friend said I could have his stock one for free.
rayman0690
Jan 4, 2026 07:20 PM
bluewaterDEMON
Lancer Troubleshooting
46
Jun 5, 2019 03:14 PM
kyoo
92
Feb 25, 2019 07:16 AM
stevedask
Outlander Sport
13
Dec 27, 2017 07:16 PM
