lifter tick?
Old Nov 26, 2015 | 11:39 AM
evolord21's Avatar
Veteran: Army
lifter tick?
Just got a new IX and it has developed a terrible sound. From looking around it could possibly be lifter tick, but it is really loud. I had a DSM and it ticked all the time, but not like this.
So I bled the lifters, same noise. Swapped them out with an extra set I had laying around, same thing.
A mechanic friend of mine said that it takes about a full day for the noise to quiet down, but I wasn't so sure. Any ideas would be awesome help. Thanks
Old Nov 26, 2015 | 12:34 PM
uneekvisions's Avatar
That sounds more like piston slap. Especially if you used some known good lifters and still had the same sound. Also when was the last time the oil was changed? Oil weight used?
Does the car have any mods?
Old Nov 26, 2015 | 01:15 PM
Jonno99's Avatar
Mileage?
Old Nov 26, 2015 | 02:35 PM
evolord21's Avatar
Veteran: Army
The car has 80k and the oil was just changed with 10w-30. I haven't verified it yet but the Pistons are supposedly wiesco and Manley h beam rods. Like I said, I just got this the other day and there was a slight tick then, but it has since gotten louder. I ticks during idle and during acceleration and deceleration. I can't hear it above 3k rpms
Old Nov 26, 2015 | 06:58 PM
barneyb's Avatar
I'd suggest pulling and cutting open the oil filter looking for any signs of metal.
Old Nov 26, 2015 | 09:17 PM
Jonno99's Avatar
Don't run it unless you have to until you get it pulled down
Old Nov 27, 2015 | 01:17 PM
Teal2nnr's Avatar
Swap your lifters or bleed them. It doesn't take too long to do....then you'll know. I had a lifter go on me this summer and it sounded similar.
Old Nov 27, 2015 | 07:32 PM
evolord21's Avatar
Veteran: Army
Already swapped the lifters. Checked the oil and it's clean. Someone else mentioned a possible exhaust leak from the manifold. Checked that and I'm not finding any leaks.
Old Nov 29, 2015 | 01:06 AM
Teal2nnr's Avatar
Do a compression check and leakdown test. See what the results are.....
Old Nov 29, 2015 | 06:09 AM
egis's Avatar
My hydraulic tensioner failed on cold start and I had noise like that.
Old Nov 30, 2015 | 05:22 PM
evolord21's Avatar
Veteran: Army
found the issue. wrist pin was loose. lost a rod, good thing is I wasn't beating on it when it dropped, so minimal damage.
Old Dec 1, 2015 | 10:53 AM
luvboost's Avatar
damn man, that was quick.
PVD04
18
Jun 25, 2012 01:20 PM
thedru13
Apr 5, 2010 08:39 AM
blackoutVIII
Dec 3, 2007 12:56 PM
coolguycooz
Sep 22, 2006 05:43 PM
SlowCar
34
Dec 9, 2005 03:04 PM
