Transmission Question/ HELP
Old Mar 3, 2016 | 07:20 PM
Duh Panda's Avatar
Exclamation Transmission Question/ HELP
So it has come time to start fixing my Evo up FINALLY
I've been looking around and found a few threads about the same problem i've been having but still cannot fix it.
SO the problem im having is my shifter in the cabin is being VERY SLOPPY.
As in you place it in 1,2,3,4,5 gear and you can move it all over the place while its in gear.
Also, its hard to get it into 1st 2nd 5th or reverse because there is so much play in the shifter.
NOW, ive checked the in cabin bushings, the shifter cables and nothing.
Went ahead and replace both the shifter bushings in the cabin AND under the hood.
I think i've found the problem with the actual shifter fork on the transmission. It's the bracket that connects from the transmission to the shifter cables.
I need help finding the parts number or maybe if someone has replaced this part? If they can share some input?
I attached a picture i found of it on the web lol
Its the whole bracket the guy is pointing at with his hand from pointer finger to pinky
Attached Thumbnails Transmission Question/ HELP-evo-transmission-shifter-bracket.jpg
Old Mar 4, 2016 | 11:29 AM
Duh Panda's Avatar
Anybody??
Old Mar 4, 2016 | 02:58 PM
egis's Avatar
http://www.streettunedmotorsports.co...d_md746246.htm
http://www.streettunedmotorsports.co...d_md745788.htm
It's 2 separate parts ain't it? It looks like one bracket.
Why do you think it's your problem anyway?
Old Mar 4, 2016 | 04:50 PM
Duh Panda's Avatar
Thanks!!
Noticed it was missing the rubber cover on it. When I started playing with it I noticed it had a lot of play in it and the one time it somehow locked up my shifter started working
Old Mar 6, 2016 | 12:50 PM
Duh Panda's Avatar
Let it be known!!! Another cause of sloppy shifter/locking out of gears is due to part MD771824
Issue solved!
Old Mar 6, 2016 | 04:52 PM
egis's Avatar
Issue solved!
thanks for sharing pls drop a link.
Edit. Never mind I got it.
Old Mar 7, 2016 | 06:58 PM
3gturbo's Avatar
Issue solved!
Is that the little half moon plastic piece?
Old Mar 7, 2016 | 10:19 PM
Duh Panda's Avatar
Just FYI this part also comes on the Dodge Ram, Chrysler Sebring and the Dodge Stratus
If youre in a bind and as cheap as i am lol NOT GOING TO PAY $10 bucks shipping for a $7 part.... You can hit up the junk yard and just nab one
ALSO in my search of finding OEM parts... I came across this very useful website http://www.mitsubishipartssource.com
It helps find the part number to whatever OEM part you are looking for AND it shows you what car models the part was also included in
SO for me... not going to pay $120 a piece for the drip molding on the Evo... You can instead get the one off of a regular lancer and its the SAME EXACT FIT. Im going to the junk yard this weekend just to confirm BUT the site says the model number is the same for both cars with the only variation being is for with/without the sunroof.
Old Mar 7, 2016 | 10:20 PM
Duh Panda's Avatar
Indeed it is! Read my above post
Old Mar 8, 2016 | 04:42 AM
egis's Avatar
Good to know brother good job lol
Old Mar 8, 2016 | 04:54 PM
3gturbo's Avatar
Didnt read it but Im familiar with it all manual mitsubishis use those
Old Mar 8, 2016 | 05:38 PM
barneyb's Avatar
Yeah, I was sitting here trying to figure out what goes wrong with a bracket. You may lift the entire transmission using the bracket and no harm. But, yeah, you need the plastic thingy.
seankhan
49
Nov 26, 2019 01:43 AM
eburhans
Lancer Tranny/Drivetrain Tech
14
Aug 28, 2011 03:35 PM
SSP Jeremy
EvoX 'For Sale' Engine Internals and Drivetrain
24
Feb 19, 2011 07:26 AM
Pro
Sep 18, 2007 02:15 PM
be12nard
Mar 11, 2005 09:15 PM
