Evo 8 downshifting problem
Old Mar 26, 2016 | 11:35 PM
Dolly's Avatar
So earlier today I was merging form one freeway to another and had to downshift from 5th to 4th, went to neutral and then as I was putting it in 4th and step off the clutch and on to the gas, I loose acceleration in the gas pedal, and the oil, battery and e-brake lights all came on for a brief maybe 2 seconds and then everything went back to normal, gas pedal working, lights went off. This is the 2nd time it's happend, and only when going from 5th to 4th. My Evo does have a slight 4th and 5th gear grind and I don't like downshifting between the 2 gears if I can help it because that's when the grind is the worst. Is almost like when the Rpms dropped to 2500 it was ok. Also no my e-brake was not on at all. She has oil, the battery is fine. I am planning on getting the tranny rebuilt sometime this year and getting her tuned in the next month or so. Any ideas?
Old Mar 27, 2016 | 06:20 AM
3gturbo's Avatar
well your car died for a second
Old Mar 27, 2016 | 07:31 AM
meckert's Avatar
^^^ this.
Old Mar 27, 2016 | 08:29 AM
Dolly's Avatar
I get that but why is the question.
Old Mar 27, 2016 | 08:38 AM
Bhsj13's Avatar
ignition switch bad?
Old Mar 28, 2016 | 01:50 PM
meckert's Avatar
Could also be the tune.., throttle slams closed, runs real rich and dies.
Old Mar 28, 2016 | 01:56 PM
Pal215's Avatar
I'm going with this.
It could also be an issue related to iac, but not likely.
-pal215
Old Mar 28, 2016 | 11:37 PM
Dolly's Avatar
I think your right about it needing a tune. It doesn't have a rough idle or anything that I would also associate with an Iac. And it does fine like she is running a little rich. I was already planning on taking her to English racing or speed factory in the next month.
Derek888
Mar 19, 2005 09:34 AM
bluebanana23
Nov 2, 2004 06:04 PM
VanillaEps
Feb 4, 2004 04:33 PM
Tristar
Lancer Tranny/Drivetrain Tech
Oct 16, 2002 11:18 AM
jlanceroz
Driving Techniques
Oct 2, 2002 11:58 PM
