Low booost?
Old Jun 25, 2004 | 05:57 AM
mattfl's Avatar
Low booost?
Last night finally installed an autometer boost gauge. My car is still stock except for a drop in K&N air filter. At idle it reads 18-20 in the vacuum, the highest boost I could get it to hit was 14 though, no matter how hard I tried could not get it up higher. I've heard that some evo's came from the factory with very low boost, in fact a friend of mine with an 03 said his was only set to 13. What is the cheapest/easiest way to fix this problem? I'm guessing a manual or electronic boost controller. Looking to save my budget here, so whats the best/most effective/best priced boost controller to get?
Old Jun 25, 2004 | 06:04 AM
AWDTurbo4's Avatar
first check all your ic, and dv connections.
Old Jun 25, 2004 | 06:09 AM
mattfl's Avatar
I'm still kinda new to this whole turbo thing....the IC connections i'm fine with, what do you mean by dv connections?
Old Jun 25, 2004 | 08:06 AM
johnjonfenomeno's Avatar
Are you sure you are pulling a 3rd gear pull.. Max boost cannot be achieved on 1rst or 2nd. That is why most Dyno pulls are done on 3rd or 4rth.
Old Jun 25, 2004 | 08:19 AM
mattfl's Avatar
I was running it up to redline in 3rd and 4th gear this morning
Old Jun 25, 2004 | 08:27 AM
leonard_shelby's Avatar
from what I have heard autometer gauges suck. Never used them myself, but I have heard they are about as usefull as stock boost gauges.
Old Jun 25, 2004 | 01:52 PM
Technoz's Avatar
the band clamps holding on the diverter valve (blow off) on the upper intercooler pipe. those have been known to be loose and cause boost leaks. There was a huge thread about it a few months ago. Not sure if it would account for a loss of 5 psi but it's worth a shot. Do you hold 14 psi constant to redline?
Old Jun 25, 2004 | 05:50 PM
mattfl's Avatar
another question, what would it mean if the vacuum is sitting kinda high, i guess normal is supposed to sit around 18-20, sometimes mines sits around 13-15
Old Jun 25, 2004 | 06:26 PM
mattfl's Avatar
I'm gonna answer my own question here after reading thru a buncha back pages on the forums..apparently this is pretty normal behavior for the autometer gauges..no worries..now, just to make sure my boost is higher than the 13/14psi it was earlier..
yancy21usa
Mar 28, 2011 01:50 PM
sith_killer_99
Dec 29, 2009 06:01 PM
tephra
Jan 22, 2008 02:25 PM
geminibby
Sep 11, 2005 05:07 PM
EvoDaWayToGo
Aug 28, 2003 01:33 AM
