How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
Old Oct 22, 2025 | 08:48 AM
  #346
ViciousLSD's Avatar
Originally Posted by RallySport9
does your garage smell like gas? I filtered the purge valve in the rear to atmosphere and can never seem to get rid of the fumes. Just something you have to live with an evap delete i guess.
no, not after the plumbing to the front. that 90deg in the pic is a check valve and needs a bit of pressure to crack. i do still have some pressure when I remove the filler cap so maybe the check valve is a restriction. I havent found time to revisit this and I'm not experiencing any issue at the moment
Old Oct 22, 2025 | 09:29 AM
  #347
dekorum's Avatar
What do you mean by “after plumbing to the front”. I thought this was default/stock. If you remove the EGR you are left with an open line in the engine bay plumbed from the rear canister. What exactly did you do to replumb it?
Old Oct 22, 2025 | 09:53 AM
  #348
Kevin.'s Avatar
Originally Posted by dekorum
Does anyone have the pictures that the OP used to describe the connections/diagram for the charcoal canister steps?
https://evoscan.com/wp-content/uploa...0002300-17.pdf - Page 21 section 17-21
Coming back to this thread, my fuel issues were with a faulty pump. Regarding the EVAP, I connected vapor hose #2 to #15 vent pipe and plugged it into that LR chassis leg slot, venting to atmosphere. Charcoal canister fills up with fumes from fill up and vents back out the purge valve at hose #1. That's the hard line that connects to the intake manifold. I haven't had a cat in 15 years so idk if I'm used to the smell or not. I only really notice fuel smell after a fill up.
Old Oct 22, 2025 | 09:56 AM
  #349
Kevin.'s Avatar
EGR gases comes from cylinder 4 in a parallel intake manifold runner, through the EGR valve and back into the intake manifold. This is why you plug it with a threaded countersunk plug at the cylinder head. The hard line from the rear of the vehicle is the purge valve line.
Old Oct 22, 2025 | 10:03 AM
  #350
ViciousLSD's Avatar
cant you see the picture? thats the tank vent to check valve to egr line
Old Oct 22, 2025 | 10:48 AM
  #351
dekorum's Avatar
which picture? I can’t see anything haha
Old Oct 22, 2025 | 10:52 AM
  #352
Kevin.'s Avatar
click this link for comprehensive knowledge of the EVAP system
Old Oct 22, 2025 | 12:31 PM
  #353
ViciousLSD's Avatar
not sure if i can help you there
https://www.evolutionm.net/forums/ev...l#post11944344
Old Oct 22, 2025 | 12:40 PM
  #354
dekorum's Avatar
haha! oh, that one. so is the right or left tube that is connected to the hardline that runs up front? Now i see that you did make plumbing changes. you entirely got rid of the charcoal canister! That is where I am headed. Your setup looks super clean
Old Oct 22, 2025 | 03:30 PM
  #355
dekorum's Avatar
I am a bit new to the 4G63 platform and the previous owner did the EGR delete. Is this the countersunk plug in my head? I see the EGR block off plate on the intake manifold and no EGR solenoid or lines in sight. My MAP intake manifold has one vacuum line plugged up and one going to the FPR. One big one in the back also going to the brake booster.
Old Oct 23, 2025 | 08:52 AM
  #356
ViciousLSD's Avatar
thats not it. its this one
Old Oct 23, 2025 | 09:14 AM
  #357
dekorum's Avatar
Oh, I see. That one can only be seen once the intake manifold is removed, correct?
Then what is the countersunk plug that I showed right next to the thermostat housing?
Old Oct 23, 2025 | 09:29 AM
  #358
ViciousLSD's Avatar
I don't know, I've never touched it.
Old Oct 23, 2025 | 09:51 AM
  #359
Kevin.'s Avatar
That's this: https://stmtuned.com/products/bspt-1...oem-mitsubishi
Old Oct 23, 2025 | 09:54 AM
  #360
dekorum's Avatar
Good find! Kind of random that mitsu did this without explaining the purpose.
Ralliartize It
Sep 12, 2013 05:44 AM
Tommytooth
Mar 1, 2013 08:45 AM
fe2o3
May 22, 2010 09:06 AM
fostytou
Oct 18, 2009 08:53 PM
EvoDan2004
28
Sep 2, 2008 07:38 PM
