How to make cheap coil on plug setup
Old Mar 15, 2012 | 09:15 PM
  #166
milruner's Avatar
so how much different was it wiring up the 4 wire toyota coil then it would be the honda 3 wire coil?
MIKE
Old Mar 15, 2012 | 09:28 PM
  #167
bluebyyouco's Avatar
i just set this up using tsx coils and i had to modify the boot since the plugs were a little bigger than factory acura ones (im running bpr7es ngks) and as soon as i started it you could hear the difference in the idle and driveability was greatly improved. awesome idea man now im working on a spark plug cover thats bolts to the coils as an assembly, ill put up pics and some instructions if it comes out good, thanks again!!
Old Mar 15, 2012 | 09:38 PM
  #168
evo8lento's Avatar
MIKE
Only difference for me was just having that extra wire hanging out, taped out of the way pretty much.
Old Mar 15, 2012 | 10:21 PM
  #169
Z_Lancer_Man's Avatar
Yeah, I just cut the unneeded "Tach" wire shorter than the other three so it was out of the way.
Old Mar 18, 2012 | 05:03 PM
  #170
spdtckts's Avatar
Veteran: Army
Sorry for the dumb questions but. I didn't notice it.on the 12 other pages for the "yaris" coils what do you mean by extend the spring and is this any issue for usability? And these are the closest coils for the dwell time correct?
Old Mar 20, 2012 | 12:56 PM
  #171
evo8lento's Avatar
Physically stretch it. As in, grab both ends and pull, but be careful not to stretch them too much. When you stretch them it'll probably come off the coil but you should be able to get them back in there. As far as dwell time, previous posts do mention that it's actually identical to the evo's. My setup works perfect; with a "slap to the face" obvious difference for the better.
Old Apr 3, 2012 | 02:31 AM
  #172
I<3 My Evo's Avatar
Bump for great write up. Definitely a future mod for me.
Old Apr 5, 2012 | 03:31 PM
  #173
kaonashi's Avatar
Can you still hide them under the stock cover?
Old Apr 5, 2012 | 03:42 PM
  #174
ReBoosted's Avatar
Awesome write up-- should be a sticky.
Old Apr 5, 2012 | 06:52 PM
  #175
From my earlier post, the following coils WILL fit under the stock cover:
Denso# 9091902240, 9008019021
Fit under the spark plug cover:
2000-2005 Toyota Echo
2001-2008 Toyota Prius
2006-2008 Toyota Yaris
2004-2006 Scion xA
2004-2006 Scion xB
Old Apr 7, 2012 | 12:25 PM
  #176
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
I have to say that after 7 months and still works awesome!!!!!!!!! everyone should do this mod...
Old Apr 7, 2012 | 12:26 PM
  #177
jonmorera's Avatar
yes you are right!!! this topic has helped many of my friends.
Old Apr 12, 2012 | 05:13 PM
  #178
dangle's Avatar
Car runs great now. If you are a person who notices the little things then this could be a night and day difference for you. My car seems much more street friendly during low rpm cruises and first gear take offs and it revs smoother throughout the rpm range.
Old Apr 13, 2012 | 06:52 PM
  #179
dangle's Avatar
delete
Old Apr 15, 2012 | 07:07 PM
  #180
droppinbottom's Avatar
I used a set of 2001 Echo coils today and made my own plate. So far works just fine. Thanks for this write up.
