Quote:
sorry, all FX-R's have the availability of LHD (or RHD) was more what I meant. They haven't ever had a revision of them that I know of that wasn't available with a LHD cutoff shieldOriginally Posted by iEvoVII
^^ haha... You couldn't be more wrong.. I've got the latest 2.5" & 3" RHD FX-Rs 3.0's sitting at home..
Quote:
Check out this quad set in action:
Specs:
* OEM Single Xenon projector replaced with an FX-R BiXenon projector.
* Morimoto 50w ballast
* Morimoto 50w D2S bulb (4300K)
Camera:
Cannon 7D set to auto (No flash)
Note: Pix may depict brighter output than they really are.
WALL SHOTS
HIGH BEAM
LHS projector needs to be adjusted down:
ROAD SHOTS:
HIGH BEAM:
STREET SHOTS:
HIGH BEAM:
ROLLING SHOTS:
I'm all for this, excellent jobOriginally Posted by iEvoVII
Specs:
Camera:
WALL SHOTS
HIGH BEAM
ROAD SHOTS:
HIGH BEAM:
STREET SHOTS:
HIGH BEAM:
ROLLING SHOTS:
Specs:
Camera:
<redacted images -llDemonll>
solid work here man. looks awesome.Originally Posted by iEvoVII
Specs:
Camera:
bumping this seriously old thread.
I just bought a set of jdm hid headlights for my evo ix
I need to swap projectors because I don't want a jdm projector to be used in america
Has anyone done anything similar to this with the newer stuff available? I plan on doing a rebuild of these lights from head to toe
i have g5-r projectors with the shields painted teal in my jdm headlights. philips xtreme vision gen2 bulbs and oem denso ballasts.Originally Posted by Jp7
bumping this seriously old thread.I just bought a set of jdm hid headlights for my evo ix
Quote:
I have to say they look very stealth and impressive. How hard were these to mount? I was surprised how incredibly easy the jdm lamps were to open.Originally Posted by evil.evo
i have g5-r projectors with the shields painted teal in my jdm headlights. philips xtreme vision gen2 bulbs and oem denso ballasts.Honestly, I am rather addicted to the idea of changing the setup in the high beam and fog light projector as well. The difficult part is that the high beam is very shallow, and the fog light is small. I plan on painting the trim grey to match the body. I will also be doing something with LEDs for the running light/parking light/signal setup. I have my heart set on 3D printing ABS mounts for LED PCB's inside (like I did with my custom tail lights I built)
Evil-Evo, did you do your own projector swap? I have everything apart, and I am looking at the HID projector adjuster motor. It snaps through the back and engages into the back of the bracket that the HID projector mounts too... I am not sure what is the best way to snap this off and I was looking for a photo or something that makes this clear...
Quote:
I answered in the other thread but I'll say it here too for others. If you are referring to the ball-socket thing just pull it a bit and it should pop out, shouldn't take much.Originally Posted by Jp7
Quote:
I finally built up the courage and pulled a little more- you were right. I removed one by just giving it a tug. I was more scared than anything! Thank you.Originally Posted by Evo9isLife
Quote:
No prob Originally Posted by Jp7
