The Official Wide Tire Thread
Old Mar 18, 2012 | 06:27 AM
  #181
n2oiroc's Avatar
Originally Posted by JDavenport
Anybody tried PF01's in the 18" sizes?
Yes, 18x9.5 +35 with 275/35R18 r888's. Just test fit last night and i need to do a little work to get them to clear. The front needed a 5mm spacer to clear the strut (bilstein hd's) and its touching the fender liner front and rear and is just touching the side skirt.
The rear fits well and i should need just a slight pull and roll or trim. Pic of the rear is with a ramp under the tire and the other 3 on the ground to compress it.
Ill update later in the week when i have time to start the mods and ill post up what i did to make them fit.
Old Mar 18, 2012 | 08:33 AM
  #182
grahamab's Avatar
eh, the tire will make it's own clearance with the fender liner and sideskirt.
seriously though, nice setup.
Old Mar 18, 2012 | 08:43 AM
  #183
n2oiroc's Avatar
I have some tricks up my sleeve for the liners, it should turn out nicely!
Old Mar 18, 2012 | 11:49 AM
  #184
SWOLN's Avatar
You'll need to also look on the inside wall on th fender, by the engine. At full lock it will rub there too. Also, dont forget to hammer or grind down the seam welds underneath the liners in the rear.
Old Mar 18, 2012 | 06:03 PM
  #185
n2oiroc's Avatar
thanks, ill add that to the list. i also have to grind and smooth the seam on the rear trailing arms. it doesnt hit, but i can barely shove a piece of cardboard between it and the tire. 265's would be so much less work.
Old Mar 18, 2012 | 06:15 PM
  #186
SWOLN's Avatar
Yeah but, then you couldn't say, "I have 275/35/18's" Also, I used a lil spacer in the rear as I still got a little rub after I massaged the rear trailing arm.
Old Mar 18, 2012 | 06:24 PM
  #187
JohnBradley's Avatar
I ran a 10mm in the front and a 3mm spacer in the rear of mine to get the 275-35/18 proxes 4s to fit on a 18x9.5 et35. Looks like the R888 must measure a little wider?
Old Mar 18, 2012 | 06:27 PM
  #188
n2oiroc's Avatar
what size/offset wheels and model tire?
Old Mar 18, 2012 | 06:29 PM
  #189
n2oiroc's Avatar
i dont have any other 275/35's to compare them to, but compared to a previous set of 265/35's on 9's the 275's buldge like all hell on 9.5's. they dwarf my 255/40R17 star specs obviously.
Old Mar 18, 2012 | 06:32 PM
  #190
The Proxes 4 definitely didnt bulge much-
Old Mar 18, 2012 | 06:35 PM
  #191
n2oiroc's Avatar
this one shows it pretty good.
Old Mar 18, 2012 | 06:38 PM
  #192
Wow, yeah for sure. When I got those wheels and tires I still worked for a NW company that sells wheels/tires/suspension. R888 wasnt out then though, the RA1 doesnt bulge like that on a 9.5, the R888 is just burly I guess.
Then again maybe the RA1 did (dont have a rear profile shot like we have above)-
275-40-17 on a 9.5 5zigen GN+
Old Mar 18, 2012 | 06:47 PM
  #193
n2oiroc's Avatar
yeah that looks pretty beefy. generally nitto/toyo are on the narrow side but their r comps are pretty big. btw, i was a shop manager for a huge custom wheel and tire store for 7 years, and donked out quite a few hood cruisers, this should be easy.
Old Mar 19, 2012 | 04:17 AM
  #194
SWOLN's Avatar
TC105's same 18x9.5 +35
The R888s measures like a 295 it seems.
If you get or make the LSD, you can put more negative camber in the rear too help with the fit...
Old Mar 19, 2012 | 10:56 AM
  #195
griceiv's Avatar
maybe not as much with the stock rear shocks.
