LOUD brake squeal
Old Jul 17, 2008, 12:12 AM
vassago's Avatar
LOUD brake squeal
i switched to hp+ pads and didn't resurface the rotors. i had about 30-35k miles on the car and all the other brake stuff is stock and i did bleed the brakes. they stop great, but the brakes are ear piercing loud. it's not ALL the time, but 90% of the time there is a squeal (or multiple from dif corners) that is at least twice as loud as brakes that have gone out/need to be replaced. i really don't know what to do at this point, i tried to break them in and have autocrossed on them so they should be set to the rotors by now (over 5k miles on them) and it's not brake dust because braking hard makes them louder (typically). is there anything i can do? is it just these pads that are this loud? it's pretty embarrassing to be driving an evo and everytime i stop have brakes that literally scream. it's like i have a symphony of screaming pads sometimes when all 4 corners are squealing at dif pitches.
Old Jul 17, 2008, 06:19 AM
Ludikraut's Avatar
HP+ will squeal, no matter what you do. When I had them on my car, it was the same deal. Ironically the PF97 pads I now run on track days, which are far more aggressive than the HP+, squeal less ...
l8r)
Old Jul 17, 2008, 06:28 AM
OhsixIXBish's Avatar
gotta take ur pads back off and put grease or anti-seize on the back of them its the vibration happened to me also put that on the back of the pad will go away!
Old Jul 17, 2008, 06:34 AM
EvoPooPoo's Avatar
Usually the Performance / track brake pads have a higher level of metallic compound, which causes the squealing.
Unfortunately, the Ferro-Carbon compound in the HP+ makes them squeal.
I have Project MU Titan kais (HC+)... HP+ is nothing compared to these.
It hurts my GF's ears...over the phone. hahahah.
Something you're going to have to live with...
Old Jul 17, 2008, 06:48 AM
Willie Dynamite's Avatar
I have Endless brake pads and they squeal like it's their sole purpose in life.
Old Jul 17, 2008, 07:57 AM
Evolessfornow's Avatar
My HP+ are the same. It doesn't matter how much you grease 'em up. Mine squeal less than 50% of the time I'm on the brakes though.
Old Jul 17, 2008, 11:26 PM
Spish's Avatar
Common prob, here was my fix, still holding up great not a peep!
https://www.evolutionm.net/forums/sh...d.php?t=347375
Old Jul 18, 2008, 05:07 PM
r1concepts's Avatar
try to re-bed in the pads. That's always a ez fix.
Old Jul 18, 2008, 06:07 PM
chaotichoax's Avatar
girodisc magic pads = no shims, no grease, and no noise
I love them
if you just daily drive it take a look
Old Jul 20, 2008, 08:09 PM
JKD
JKD's Avatar
Yup my HP+ pads squeal horribily too. Nature of the beast.
Old Jul 20, 2008, 11:58 PM
huevosrancheros's Avatar
U can try that. There is something like this at autozone. Different brand though. You apply directly to the rotor.
There is another spray(I forgot name) also at vatozone, that sprays directly to the backing of the pad. It leaves a some what thick residue. Did you clean the bindings the hold the pads down and did you use break grease on the pins????
Old Jul 21, 2008, 12:11 AM
AEvo2Nv's Avatar
Thats the normal thing for hp+ pads buddy.
Old Jul 21, 2008, 11:27 AM
SeanJhn9's Avatar
whats up man, did you put the shims back in? that same thing happened to me when i did my pads, i forgot to put the shims back in and it squealed like crazy...i had to go to larry miller and order some new shims
Old Jul 21, 2008, 01:20 PM
I was driving my car today for about an hour. Mixed city and highway driving. My HP+ pads barely made a peep.
Old Jul 21, 2008, 01:33 PM
emolution's Avatar
my hp's were so loud it hurt my ears, but after a looooooong time they seemed to only be loud after getting really hot.... but i couldnt do anyhting to fix them. i even had the dealership give me new calipers (because the clear was pealing) but still nothing. you just have to deal with it i guess :/
Bhsj13
13
Apr 5, 2017 04:26 PM
4g63xawd
62
Jan 6, 2016 03:25 AM
AustinB768
14
Aug 1, 2012 03:03 PM
Piro Fyre
23
May 15, 2010 12:34 PM
naucrx
29
Sep 7, 2009 08:18 AM
Quick Reply: LOUD brake squeal
