2012 Evo X MR 2.2L GTX3071 MooreTuned - 441/346
Here's a build we finished up about a month ago, just getting around to putting up the results.
2012 Evo X MR
Fuel: 93 Octane
Boost: 28psi
AMS 2.2L Overbore Bottom End
Cosworth MX1 Cams
Garrett GTX3071 direct replacement turbo
FiD Turbo Manifold
ETS Downpipe
Test Pipe
Magnaflow 3" CBE (modified with 3" inlet flange)
AEM Intake
ETS Intercooler and Piping
Synapse DV
Next up is building the SST to handle more power
~Chris@MooreAutomotive
2012 Evo X MR
Fuel: 93 Octane
Boost: 28psi
Cosworth MX1 Cams
FiD Turbo Manifold
ETS Downpipe
Test Pipe
AEM Intake
Synapse DV
nice #'s
2012 Evo X MR
Fuel: 93 Octane
Boost: 28psi
Cosworth MX1 Cams
FiD Turbo Manifold
ETS Downpipe
Test Pipe
AEM Intake
Synapse DV
2012 Evo X MR
Fuel: 93 Octane
Boost: 28psi
Cosworth MX1 Cams
FiD Turbo Manifold
ETS Downpipe
Test Pipe
AEM Intake
Synapse DV
Sweet, finally somebody with results, thank you for posting! This will be my next, so full boost around 3-3500, does it taper to 24-25 uptop? Hows wga holding up on this? Is this .73 or .94 trim?
Hows the transient response on low-midend , thanks
WHAT??? why would you want an MR instead of your GSR lollll???? GSR would have made 20-25whp more....yes the MR shifts faster....but i **** you not.....get a TWM short shifter and some engine mounts and your GSR will be an MR lollll .... im speaking by experience my friend has an MR!!!
very very very nice build BTW...im going the same way except 2.4 on my fp red and TMP's cams!!! very nice car you have there!!!
How did find boost its not in the log ?
A stock X usually puts down anywhere from 240-260 depending on the car on our dyno.
I believe he has the .73 housing, it's hitting full boost at 4100rpm (in 3rd).
I had to do a bit of creative tuning to the SST tables to keep from hitting the torque limiters and cutting out.
